oliver789 Posted August 7, 2012 Share Posted August 7, 2012 Hi all, Two weeks ago I changed all my pads and put on anti squeal shims. I have done about 100 miles since then but they are still squeal/squeaking when I gently squeeze the brake pedal at low speeds i.e. parking. Any ideas what could be causing this. Cheers Quote Link to comment Share on other sites More sharing options...
Ricey Posted August 7, 2012 Share Posted August 7, 2012 I thought the brembos just squealed a bit? Try some copper grease on the back of them. Quote Link to comment Share on other sites More sharing options...
Ekona Posted August 7, 2012 Share Posted August 7, 2012 They probably just need a good bedding in. 10 x 50-30 with light pressure one after the other Cooldown 10 x 70-40 with medium pressure Cooldown 10 x 100-50 hard as you can but without triggering ABS Cooldown Should sort it. Quote Link to comment Share on other sites More sharing options...
coldel Posted August 7, 2012 Share Posted August 7, 2012 Will take a while, bedded mine in with a long trawl around the M25, good way to do the braking is to come off at junctions and brake down (obviously try to make sure no one is behind you!) Quote Link to comment Share on other sites More sharing options...
