Replacing rocker cover.
stevo1179
I have done a search, but have found conflicting information.
I have the parts and my father-in-law is a mechanic, he would replace the part but is concerned that the inlet manifold would need to be removed.
The general impression I get is that it's ~1.5 hour job, but the only detailed description I have found (link to american forum) suggests its more 7 hours (for both sides) and it eluded to the inlet manifold being removed, see below.
http://my350z.com/forum/engine-drivetra ... skets.html
Any advice would be greatly appreciated,
Steve
I bought the cover and a single gasket from you a couple of months ago. Is this all I need?
If you are only doing one side you will only require 1 cam box gasket.
Most reuse the mid and lower plenum gaskets.
Some RTV as per evilscorp post :thumbs:
Alex :)
at work on phone so cant search very good but if i remember right its at the corners only front and back, just a small anount, post a thread asking for the manual, tells you how to rebuild the entire car! Might have done a write up myself will look through old posts :bangin:
