Water trapped between sill & door
dragon
I do have an easy fix for this: park with the nose down hill. Mine collects water but only when parked nose up. :thumbs: Water gets in and gets trapped below the back of the door, but seems to drain ok from the front of the door.
I suppose if you are parking on a flat you maybe stuffed however. :lol:
Same here....park nose up and water collects....park nose down (even slightly) and no water :). The car should not do this though :thumbdown:
