Remapping
Markoose
Hi all,
Fairly simple answer id imagine but i dont know it, hence begging you kind folk for the answers.
My car has a cool air intake, Berk Decats and a wonderful ecu light.
Whats better (or are hey the same) Horsham or Abbey ? Will i get near 300-305 ? If i use v power constantly and map it with v power.
The ECU light can be solved with the sensor spacers - :pmzmanalex:
EDIT : If thats what is causing it!
I think they can turn them off on a remap if you're having it done.
300 - maybe, maybe not maybe more you won't know until you put it on a dyno, also depends what you had before.
Fuel is not the only factor, each engine will be different out of the factory then there is wear and tear to take into account.
