speedwell Posted August 2, 2012 Share Posted August 2, 2012 Is there a guide anywhere as to how to do this? (search done,nothing comes up) Would like to know what's involved to decide if I can tackle it myself. Thanks, John. Quote Link to comment Share on other sites More sharing options...
Leeroy Posted August 2, 2012 Share Posted August 2, 2012 Can't help with the fitting, but are you sure you need the whole arm? If the ball-joint isn't borked you can replace the bush on the other end with a Superpro item or similar, for much less cost Quote Link to comment Share on other sites More sharing options...
speedwell Posted August 2, 2012 Author Share Posted August 2, 2012 Can't help with the fitting, but are you sure you need the whole arm? If the ball-joint isn't borked you can replace the bush on the other end with a Superpro item or similar, for much less cost I think it's the ball joint,or rather hope it is...the guess work that is the 350z front suspension,don't you just love it! Quote Link to comment Share on other sites More sharing options...
John tarantula Posted August 2, 2012 Share Posted August 2, 2012 If it's just the bush you'll need to get it pressed in and out of the arm so unless you have your own press that you can get to the car you'll need the arm off. We tried when i replaced my bush and gave up and pressed the bush in and out in situ! Quote Link to comment Share on other sites More sharing options...
