2222Piggy Posted July 29, 2012 Share Posted July 29, 2012 Afternoon all I have just been for a run in the Z and on my way to the petrol station, the engine light has appeared. I havent been driving it any different than usual and it still drives spot on, no change there What could it be? Im thinking its nothing serious because its not effected its drive in any way. Should i just take it down to Nissan and let then stick it on the diagnostics Thanks in advance Quote Link to comment Share on other sites More sharing options...
JackStrong Posted July 29, 2012 Share Posted July 29, 2012 do the pedal trick to find the code. Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted July 29, 2012 Share Posted July 29, 2012 or get someone with an obd2 code reader to check it for you. Nissan will cost a fortune. Where are you based? has the car been decatted? Quote Link to comment Share on other sites More sharing options...
2222Piggy Posted July 29, 2012 Author Share Posted July 29, 2012 Peddle trick? Im in Bingley, and the car has not been decatted Cheers Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted July 29, 2012 Share Posted July 29, 2012 do you know anyone with a code reader. I just bought mine off ebay for £15. its ALOT cheaper than what nissan would charge you for a diagnostic. Then when you find out what the code is you can phone up a private garage and they should tell you what is wrong with it. The peddal trick should be on the forum somewhere but i dont think the search is working properly just now. You do something with the pedal and the EM light flashes so many times to give you a code i think but ive never tried it.Im sure someone will be along shortly to let you know how to do it Quote Link to comment Share on other sites More sharing options...
Neilp Posted July 29, 2012 Share Posted July 29, 2012 search in the guides section. Loads of info on here as long as you are willing to search. I think it comes under pedal dance or something similar. Quote Link to comment Share on other sites More sharing options...
2222Piggy Posted July 29, 2012 Author Share Posted July 29, 2012 Still cant find it Anyone link me to it? Cheers Quote Link to comment Share on other sites More sharing options...
Neilp Posted July 29, 2012 Share Posted July 29, 2012 http://www.350z-uk.com/forum/viewtopic.php?f=35&t=55272 350z faq, guides, then about 6 or something links down. Quote Link to comment Share on other sites More sharing options...
2222Piggy Posted July 29, 2012 Author Share Posted July 29, 2012 That only explains the reset procedures Im after the error codes cheers Quote Link to comment Share on other sites More sharing options...
Will370z Posted July 29, 2012 Share Posted July 29, 2012 Read part way down this thread. Stop half way through the reset procedure to read the flashing lights viewtopic.php?f=64&t=32409&hilit=Engine+reset+procedure Quote Link to comment Share on other sites More sharing options...
2222Piggy Posted July 29, 2012 Author Share Posted July 29, 2012 Magical Ive done it A bit of a fuss but i got it after the 4th time! I think it read 1142 OR 1141 I videod it on my ipad, anyone know anyway i can upload to here? Any ideas on the code? Cheers Quote Link to comment Share on other sites More sharing options...
Will370z Posted July 29, 2012 Share Posted July 29, 2012 Theres a thread on here with all the codes somewhere i'll see if i can find it Quote Link to comment Share on other sites More sharing options...
2222Piggy Posted July 29, 2012 Author Share Posted July 29, 2012 Ive had a quick search, i came across it this afternoon and now i cant find it Quote Link to comment Share on other sites More sharing options...
Will370z Posted July 29, 2012 Share Posted July 29, 2012 Here you go viewtopic.php?f=17&t=21762 Quote Link to comment Share on other sites More sharing options...
2222Piggy Posted July 29, 2012 Author Share Posted July 29, 2012 Thanking you! Although, it doesnt have my codes I may have read it wrong, anyway i can upload the video for someone to check? Cheers Quote Link to comment Share on other sites More sharing options...
Will370z Posted July 29, 2012 Share Posted July 29, 2012 Sure post it up. Always used to drive me mad trying to watch all those flashing lights and work out what the code was. Quote Link to comment Share on other sites More sharing options...
2222Piggy Posted July 29, 2012 Author Share Posted July 29, 2012 How do I post it up? I usually use imageshack for my photos Cheers Quote Link to comment Share on other sites More sharing options...
Will370z Posted July 29, 2012 Share Posted July 29, 2012 Photobucket or youtube for vids Quote Link to comment Share on other sites More sharing options...
2222Piggy Posted August 5, 2012 Author Share Posted August 5, 2012 Bonjour! I booked this into nissan for a diagnostic and to fix the fault.... I set off at 8am to take it......and the light went off by itself! It must of known it was in trouble Still, i took it in and explained. They still wanted 50 sheets to plug it in and see what the fault WAS. Told them no, i'll bring it back if the light comes back on Its stayed off ever since Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted August 5, 2012 Share Posted August 5, 2012 Self healing zed Quote Link to comment Share on other sites More sharing options...
