Wheel nut size?
Yella Fella
Yes 12x1.25 is correct, the taper is the angle of the bottom of the nut which sits flush to the wheel (its a cone shaped end), as far as I have seen all are 60 degrees standard. If in doubt contact rare rims, they are on here as well as on ebay.
OE nuts for OE wheels generally are no good on aftermarket wheels, as they're larger.
For example our nuts generally have a 17mm head or a tool that uses a 17mm head.
All Nissans I can think of are M12x1.25, this is specific to the car, not the wheels :)
To be 100% sure which nuts will suit you if you can let me know which wheels you have I can give some more useful advice :)
