DaJimstar Posted July 23, 2012 Share Posted July 23, 2012 Hi all, when I 1st got the Z it was a little difficult untill warmed up, to get it into/change from first to second gear, as we know a common minor-issue. I have had the gear box and rear diff oil swapped out, and its made one hell of a difference. It is sweeeeeeet in transition now .. Not used molyslip yet, just seeing how I got on with swap out .. just sharing . Its a real real pleasure to drive now Thanks to Alex and this forum for supplying me with info on this common characteristic.. . Just sharing in case it helps someone else. Quote Link to comment Share on other sites More sharing options...
sunshine Posted July 23, 2012 Share Posted July 23, 2012 It's a common issue, to be honest mine could do with a oil swap and i put castrol stuff in last and its Sh1t. Quote Link to comment Share on other sites More sharing options...
Ken Posted July 23, 2012 Share Posted July 23, 2012 It's a common issue, to be honest mine could do with a oil swap and i put castrol stuff in last and its Sh1t. for Nissan gearbox and diff oils. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted July 24, 2012 Share Posted July 24, 2012 for Nissan gearbox and diff oils. +1 Quote Link to comment Share on other sites More sharing options...
Paddy78 Posted July 24, 2012 Share Posted July 24, 2012 I changed mine a few weeks ago, but it didn't seem to make much difference. Should it sound like the gearbox is about drop out when changing into 1st and 2nd? I know that the Zed has a clunky transmission, but it always worries me as it's really loud. Quote Link to comment Share on other sites More sharing options...
coldel Posted July 24, 2012 Share Posted July 24, 2012 Nissan gearboxes are notorious for being noisy, best thing is some Nissan gear oil from Alex along with some molyslip, will help reduce noise. Quote Link to comment Share on other sites More sharing options...
Paddy78 Posted July 24, 2012 Share Posted July 24, 2012 Yeah, did that... not much improvement. Oh well, I guess the emergency clutch / gearbox fund will have to be increased! Quote Link to comment Share on other sites More sharing options...
coldel Posted July 24, 2012 Share Posted July 24, 2012 I wouldnt just go out and buy a replacement gearbox though! Could be thats just as noisy and clunky as your current one. Even the fabled CD009 boxes are not as invincible as they are made out to be (although technically they are better), read somewhere about someone changing theirs out to one of these and it was just as clunky. As long as it doesn't interfere with your driving the noise should be something you can live with. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 24, 2012 Share Posted July 24, 2012 Yeah, did that... not much improvement. Oh well, I guess the emergency clutch / gearbox fund will have to be increased! Guaranteed preowned gearboxes in stock Quote Link to comment Share on other sites More sharing options...
taffyjason Posted July 24, 2012 Share Posted July 24, 2012 same issue here, changed oils for nissan why molyslip, its still pants when cold Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted October 22, 2012 Share Posted October 22, 2012 Is it fairly easy to slip a bit of Molyslip into the gearbox ? I did it on my MR2, and it definitely felt a lot better afterwards. I'm just noticing the little clunk from 1st to 2nd as well, kept thinking it was my dodgy shifting Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 22, 2012 Share Posted October 22, 2012 Best to change the gearbox fluid at the same time as you add the Moly. Proper gearbox fluid and DC Moly in stock and good to go same/next day. Easy to swop out the fluids but much easier on a ramp. Alex Quote Link to comment Share on other sites More sharing options...
Leeroy Posted October 22, 2012 Share Posted October 22, 2012 Is it fairly easy to slip a bit of Molyslip into the gearbox ? I did it on my MR2, and it definitely felt a lot better afterwards. I'm just noticing the little clunk from 1st to 2nd as well, kept thinking it was my dodgy shifting It's normal from cold Rob, you've probably noticed it disappears when it's warmed up Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted October 22, 2012 Share Posted October 22, 2012 Hey Alex, Gear box and diff oil changed recently, so all good there. Just want to squeeze a bit of moly in there. It's normal from cold Rob, you've probably noticed it disappears when it's warmed up Yeah definitely noticed, I've seen that it's worth going from 1st to neutral, then to 2nd (d.declutching). I'm heading to H.Dev in Nov so perhaps will get some sorted out then, rather than me tarting about in the cold Quote Link to comment Share on other sites More sharing options...
Leeroy Posted October 22, 2012 Share Posted October 22, 2012 I'm heading to H.Dev in Nov so perhaps will get some sorted out then, rather than me tarting about in the cold Nice one, Jez will look after you. What are you having done? I always planned to fit a plenum spacer and HFC's and uprev map it, but never got around to it......you won't see much of a power gain but the car should be even better to drive and listen to Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted October 22, 2012 Share Posted October 22, 2012 Nice one, Jez will look after you. What are you having done? I always planned to fit a plenum spacer and HFC's and uprev map it, but never got around to it......you won't see much of a power gain but the car should be even better to drive and listen to Heh, exactly what I'm intending to do but just need to give him a call, may need to postpone it now until the MR2 has gone. doh Quote Link to comment Share on other sites More sharing options...
Leeroy Posted October 22, 2012 Share Posted October 22, 2012 Heh, exactly what I'm intending to do but just need to give him a call, may need to postpone it now until the MR2 has gone. doh Ah well, at least you'll get used to the stock power and will appreciate the differences Quote Link to comment Share on other sites More sharing options...
