slimjim Posted July 18, 2012 Share Posted July 18, 2012 Not had time to take it apart yet.... But the passenger side window isn't working I can hear the click in the door, if I use the drivers side or passengerside switch. But nothing happens. Nothing to do with the window lock on the drivers side, tried that. The window doesn't even drop when you open the door.... So it doesn't shut properly.. Any ideas peeps? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 18, 2012 Share Posted July 18, 2012 Permanent fix here mate viewtopic.php?f=157&t=43453 Alex Quote Link to comment Share on other sites More sharing options...
R35LEE Posted July 18, 2012 Share Posted July 18, 2012 If you need a motor or regulator I can sell you one cheap mate Quote Link to comment Share on other sites More sharing options...
slimjim Posted July 18, 2012 Author Share Posted July 18, 2012 Permanent fix here mate viewtopic.php?f=157&t=43453 Alex If you need a motor or regulator I can sell you one cheap mate Knew I could count on you guys! I think I need to take the door apart and have a look. Could it just be a fuse? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 18, 2012 Share Posted July 18, 2012 Doubt if it will be a fuse mate. You can always strip the motor as in the guides section however IMHO best to fit a new one and forget about it Alex Quote Link to comment Share on other sites More sharing options...
slimjim Posted July 18, 2012 Author Share Posted July 18, 2012 Doubt if it will be a fuse mate. You can always strip the motor as in the guides section however IMHO best to fit a new one and forget about it Alex You know me so well... Quote Link to comment Share on other sites More sharing options...
smudgedon Posted July 18, 2012 Share Posted July 18, 2012 Check my recent thread in the technical section. A soft bang on he doorcard where the motor is located allowed me to get the window back up Quote Link to comment Share on other sites More sharing options...
slimjim Posted September 8, 2012 Author Share Posted September 8, 2012 Check my recent thread in the technical section. A soft bang on he doorcard where the motor is located allowed me to get the window back up Hmm... the bang on the door didn't work. So, is there any point in me trying to check if the power is setup right? Or so I just need to replace the motor, as Al says.... Just don't really want to fork out £150 when I am trying to sell it, unless I have to. But I do want it right before I sell it. Is everyone SURE it will be the motor? Is there anyway I can test it? The passenger side "control box" clicks if you use the button... and also if you use the passenger button from the drivers door. So I am 100% sure it is getting power. Would a multi-meter and a bit of advice allow me to be positive I need to replace the motor? Advice peeps? N.B. I unplugged this, just for the photo.... Cheers guys! Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 17, 2012 Share Posted October 17, 2012 I just had the motor replaced in the O/S door of my Zed, i've not had my Zed for that long but it appears to be a common problem. I tried cleaning the motor but this was only a temporary fix, maybe i wasn't thorough enough i don't know but a couple of weeks later i was faced with same problem. I didn't even get the 'click' that you mentioned, mine was as dead as a Monty Python parrott. A new motor and no problems, its amazing how much quicker the o/s window winds and unwinds compared to the n/s window. I have a feeling i have the same problem just waiting around the corner with the n/s window. Quote Link to comment Share on other sites More sharing options...
