Nissan 2007 56 Plate Clicking (tick) noise
hi everyone, there is something wrong with my car i think, when i try to pull up there is this clicking noise and also i hear the same noise when i break.. i only hear this noise when i go 0-20 mph after 20mph i don't hear it. i hope someone knows whats the problem im a bit worried.. :(:shrug:
Clicky Axle. Well documented problem with the Zed.
Either search (best to use google -include "350z-uk" in your search field) as the sites search function is borked at the moment).
Or
Look in the guides section as their is a detailed thread on how to fix it.
ZMANALEX sells full repair kits.
Your rear axle drive shaft flange needs lubricating. Easy job , low cost, 1 hour max.
Try 350z.com and input clicking axle in the search bar.
Good video guide to fixing the problem.
Did mine a month ago .... no problems since then.
Good luck
Thank for the reply, i feel much better now, i thought it was the gearbox.. :thumbs:
Yay :yahoo:
relief overcomes the realisation that even after a year you have missed probably the most common talked about problem on the entire forum :lol:
