Passenger window ghost
Plummerman
Hiya folks
Having a intermittent issue with passenger window, if I open the door window will drop as it should, close up after door closes but then drop down to a third open :wacko:
It also does this if you open/close it from the inside on the button.. You have to hold the window button up for around ten seconds to get it to stay up
Has Anyone come across this before or know of a solution for it
Cheers Phil
