andylb Posted July 13, 2012 Share Posted July 13, 2012 I have the bose system, and have the issue with the sub cutting out. Had cookie do the ribbon reinsertion mod a while back to fix the left hand side cutting out, so I don't think it's this. I tried the fix of opening up the box and wedging some paper in, but it didn't fix it. Anyone know of a possible fix to this? Is there anyone around the south east way that can offer a fix for it? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted July 13, 2012 Share Posted July 13, 2012 I fixed mine by unlpugging it and buying a much better sub Not that helpful but personally I wouldn't be faffing around trying to fix something that sounds like a tortoise farting in a shoe box Quote Link to comment Share on other sites More sharing options...
andylb Posted July 13, 2012 Author Share Posted July 13, 2012 I fixed mine by unlpugging it and buying a much better sub Not that helpful but personally I wouldn't be faffing around trying to fix something that sounds like a tortoise farting in a shoe box It's a good point, but then won't I need an amp as well, and then a new head unit to connect it to? I actually dont think the sub is that bad when it is working, provides a bit of bass, I don't need loads. Quote Link to comment Share on other sites More sharing options...
trackpig Posted July 13, 2012 Share Posted July 13, 2012 The relay in the amp gets a bad connection in my experence. Remove sub Remove amp from left hand of sub area (left hand side when work via driver door) disassemble the metal cover of amp Fit new circuit board or fit new relay OR use sticky pads ontop of the black relay to pack and apply pressure to the top of the relay when you build the cover back up. The applied pressure makes the poor connection and the amp work. This worked for me, it may not work for you but its worth a try. Quote Link to comment Share on other sites More sharing options...
