Builder49 Posted July 11, 2012 Share Posted July 11, 2012 I make no secret of the fact that my vehicle related knowledge is pretty poor....... I can change a wheel, put in fuel and turn the ignition key, and thats my technical limit... My 61 plate Navara is flashing the low oil symbol to me, and has been for the last couple of days Now even I figured I could put oil in (and indeed I do know where it goes), but the type of oil is giving me a headache as I dont understand the mumbo-jumbo I'll quote from the owners manual..... With DPF engine: Genuine NISSAN engine oil *1 ACEA C3 and C4 LOW ASH 5W-30 HTHS 3.5 *1 Without DPF engine: Genuine NISSAN engine oil API grade CF-4 *1 *3 ACEA B1, B3, B4, B5 *1 Can somebody tell me what the hell that means in English (Scottish, Welsh or Irish) I'm happy to admit I'm a numpty, but I can do other things that are not vehicle related very well Thanks in advance guys, (and feel free to take the p**s at my lack of knowledge), but better to ask than put something wrong in a vehicle with only 5000mls on it. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 11, 2012 Share Posted July 11, 2012 i hope for your sake it oil level indicator and not oil pressure indicator. Normally its oil pressure. If it is and you've been driving around with it like that you may have goosed your engine. does your car have a DPF? This is a diesel particulate filter (part of the exhaust) if it does then you want some 5W-30 oil for Diesel Engines Quote Link to comment Share on other sites More sharing options...
Builder49 Posted July 11, 2012 Author Share Posted July 11, 2012 Cheers Mike. Its the oil pressure/level warning light. Only flashes for less than 30 seconds when I turn the ignition on, and only started about 3 days ago. As for the DPF thing? How do I know or find out?????? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted July 11, 2012 Share Posted July 11, 2012 If it is a derv it will almost certainly be a DPF as those are now compulsory I believe.... Quote Link to comment Share on other sites More sharing options...
Builder49 Posted July 11, 2012 Author Share Posted July 11, 2012 It is Diesel and it also flashes up OIL Lo when I start, which apparently indicates its a case of low oil level, not low oil pressure? So on that basis I need 5W-30 for diesel engines ????? Quote Link to comment Share on other sites More sharing options...
Ekona Posted July 11, 2012 Share Posted July 11, 2012 Have you checked the oil level yet?! Yes, you need 5w-30 diesel oil, although tbh anything around those numbers will suffice. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 11, 2012 Share Posted July 11, 2012 Cheers Mike. Its the oil pressure/level warning light. Only flashes for less than 30 seconds when I turn the ignition on, and only started about 3 days ago. As for the DPF thing? How do I know or find out?????? when the light comes on that basically means your running now oil around all the essential parts. Your grinding metal against metal with no oil to lubricate and to prevent damage. Level is a very different thing to pressure. How does it let you know if its level or pressure? Is it on start up it tells you the level then when running it pressure? edit... just seen you reply while I was typing. 5w-30 it is then Quote Link to comment Share on other sites More sharing options...
Builder49 Posted July 11, 2012 Author Share Posted July 11, 2012 Thanks for your help guys, shooting out to get some oil now. Cheers Paul Quote Link to comment Share on other sites More sharing options...
Chris AME Posted July 11, 2012 Share Posted July 11, 2012 Most navara's do have DPF i think it is only non euro spec models which do not if i remember correctly, it needs topping up asap as it doesnt take long for damage to be done Quote Link to comment Share on other sites More sharing options...
Allan Zada Posted July 11, 2012 Share Posted July 11, 2012 Make sure you buy an oil meeting the nissan specs for that engine. If it has a dpf fitted (would imagine it has on a 61' plate) and you put the wrong oil it, it will cause excessive soot to build up in the diesel particulate filter and block the filter. Leading possibly to a costly repair Quote Link to comment Share on other sites More sharing options...
