Without the sour..........
Ricey
......the sweet just ain't as sweet.
Merc back from garage today with an £850 bill to sort the little judder that it had under low rpm acceleration......basically rad had failed and contaminated auto box with glycol.
3 days being told wrong rad arrived blahblahblah. Eventually pick it up and he advises that he's installed the wrong rad to get me on my way but to come back tomorrow/thurs as the correct one will be in (only difference he reckons was a pipe at the top that's blanked on the right one that isn't on this one and he's put a temp blank on).
Drive car home......perfect. Smooth as silk and pulling like a train. No juddering, no slipping just perfect
Get home and then drive to footy.....2 miles down the road it starts slipping and then slips completely (like you would imagine if a clutch totally failed on a manual). then it started whining (which went after a couple of restarts).
Stop and started car and it was pulling again but no changing gear.......then going back to slipping again.
Christ knows what they've done but I don't understand how a gearbox can be perfect then 2 miles later slipping and stuck in first. Also when clutches go they dont suddenly spring back to life when you restart the car.
Paralysed with fear is about the best way I can describe myself now. :cry:
  • Replies 73
  • Created
  • Last Reply
Top Posters In This Topic
Verdict......2 new valves required apparently
Conveyed to me over voicemail so not sureif he's expecting me to pay for them or not.
Not sure if that's an expensive part or not.
Why why why didn't you get a Zed..... It just makes sense all this expensive merc stuff.
You just wanted to be different didn't you :stir:
he still has access to one :shrug: and remember car ownership is not like marriage, just because you found something you can live with doesn't mean your not allowed to go out and try other cars. or have car flings. :lol:
he's just moved up to the big leagues, dating a high maintanence girl, she needs alot before she puts out, but when she does; she sure knows how to show off. :lol:
he still has access to one :shrug: and remember car ownership is just like marriage, just because you found something you can live with doesn't mean your not allowed to go out and try others, or have flings :lol:
he's just moved up to the big leagues; dating a high maintenance girl; she needs a lot before she puts out, but when she does ... she sure knows how to show go some :lol:
I wouldn't mind a go with yours Rich :)
merc owner
he still has access to one :shrug: and remember car ownership is just like marriage, just because you found something you can live with doesn't mean your not allowed to go out and try others; or have flings. :lol:
he's just moved up to the big leagues, dating a high maintenance girl, she needs a lot before she puts out, but when she does; she sure knows how to show off. :lol:
meant to say is not like marriage, will correct in a sec :lol:
your more than welcome to try, when ever we're both at a meet together, and she's defo a girl,
I want a car with more than 2 seats for a bit as well.......sick of having to drive both cars to take more than 2 people anywhere!
Never mind.....one of those learning experiences at the end of the day. Expensive one but thats life.
Hopefully either the garage is covering the cost for damaging the gearbox after bodging the rad or its a cheap fix. He's getting some @*!# tomorrow if he's not planning on doing it for free!
This is what happened to my bro's clk 55. when you planted it, it lost power. I'm sure i said this when you first bought it or thought about it.
Hope it isnt the same thing as his needed a full new box. :bang:
Good luck mate
Good luck mate
This wasn't when you plant it mate - it was running perfect for 15 miles then literally slipped like the clutch was gone completely - no power at all.....planting it or not.
Already checking out the other options :teeth:
Why do I now have a mental image of ricey squatting over a shoe box :headhurt:
Actually something as occurred to me that makes a lot more sense.......it might not be slipping - its jumping into neutral.
That would explain why it went from perfect to nothing...clutches simply don't go fail in 20 seconds from perfect to total slippage.
Oh someone mentioned something about clutch plates?
I don't get gearboxes.
Merc forum just asked the same question! I don't know.....just got a garbled voicemail message about it needing 2 new valves.
actually there are clutches in an auto box, about 5 or 6 of them actually :p
Its not really a friction plate like a manual car though I know there is though. Usually the TC is effected but the glycol issue and is the cause of alot of failures.
Bizarre.......just had a call from the garage.
Bloke has now said he's had a think about what I said and come to the conclusion that he can't charge me any more to fix the car.
He's got onto the company that told him the rad would be ok to temporarily fit and said they need to foot the bill.......apparently its being looked into by a gearbox specialist.
Sounds like the valves mustn't have fixed it then!
