OEM front disk durability
ashyk36
If you come in for a landing and don't stop gently consistently, then they'll wear really fast. Also if you have a tiptronic and don't use the manual gears, maybe heavier on brakes too.
More to the point, why are you asking? Are you looking at other non-OEM options?
If you confirm whether Brembo or JDM I will post up the original and minimum thickness dimensions for you, and you can then measure your rotors and compare. :thumbs:
There is no recommended mileage for rotor wear as so many different factors must be taken into consideration.
Alex :)
