Boot switch,
jon.young
Hi all, when I fitted the catch for my boot release I didn't have a
Battery on the car so couldn't test it, now I have power, I can't get it to open via the switch by the number plate.
I had it all apart yesterday, an using a battery charger ran 12v through the switch and tested it with
A voltmeter, the switch seams to only work one way around, but when it's all connected it dosent work,
I also linked out the switch to basically simulate the switch being pressed nothing happened, but when
I linked it to neg the solenoid work on the release mech?
Anyone got some ideas???
The car has got an aftermarket alarm fitted, I dunno if it's worth seeing if I can wire the boot release to that? An by pass the switch?
Any thoughts are welcome
Thanks Jon
Thanks Jon
I think you answered your own question there, unless the switch is just faulty :shrug:
I think I will pull the alarm out find the model and temp wire the trigger wire to the solenoid
See if I get any joy,
It's just weird how linking the switch out has no effect either, which I should make it work
The boot release is obviously on the alarm 'ring' so if someone has bodged a connection somewhere that would explain it I guess... hope you get it sorted buddy :thumbs:
