Heat from engine
Mikesding
Hi guys - just wondered how much heat is normal from the engine? Noticed the other day I could feel the heat from the engine when standing near it quite noticeably; the coolant temp inside is fine and oil is fine so wondered if this was normal for a bigger engine?
Cheers!
Feel the tunnel where the gearbox is at the side of your left foot inside the cabin ;) all my chocolate melted on a drive out in the passenger footwell. I have decats though so its even warmer
this was the first thing I noticed when I got my car! Wondered why my left leg felt so hot...
How come it gets so hot from a mechanical point of view? Bad lubrication?
It's a large, fairly powerful engine with little venting for hot air.
The more power an engine produces, the more heat it will produce, it's why supercars are generally covered in vents and ducts.
I'm sure Nissan will have adressed the heat issue plenty enough for a standard car, at least, so I wouldn't worry about it.
A couple of cars ago I had an E30 3-series BMW with a turbocharged BMW 535i engine, it melted the abs sensor wire on the inner wing!
Not enough cooling / venting / shielding!
