SwainTrain Posted July 4, 2012 Share Posted July 4, 2012 Hi all, Just had a full service and some work done (new front discs and pads, new belts plus some rust on the cat seen to) at H-Dev but a couple of other issues came to light. They all will be similar in cost to put right but of course I don't have the luxury to get them all sorted at once. The question is, in what priority would you get the following dealt with?: Front bushes needing replacingFront + back drop links replacing (creaky rear syndrome)Front wheel bearings needing replacing Any input helpful. Quote Link to comment Share on other sites More sharing options...
docwra Posted July 4, 2012 Share Posted July 4, 2012 Bearings? As in wheel bearings? Do them first as they will get loud and annoying otherwise, then the bushes, then the droplinks. Quote Link to comment Share on other sites More sharing options...
Wasso Posted July 4, 2012 Share Posted July 4, 2012 Bearings? As in wheel bearings? Do them first as they will get loud and annoying otherwise, then the bushes, then the droplinks. +1 to that Quote Link to comment Share on other sites More sharing options...
kbeast35 Posted July 4, 2012 Share Posted July 4, 2012 ^^^^what they said Quote Link to comment Share on other sites More sharing options...
Cragus Posted July 4, 2012 Share Posted July 4, 2012 Amen Quote Link to comment Share on other sites More sharing options...
KyleR Posted July 5, 2012 Share Posted July 5, 2012 Drop links are pretty cheap, get them done at the same time as the bushes, after the bearings. Quote Link to comment Share on other sites More sharing options...
cmck13 Posted July 5, 2012 Share Posted July 5, 2012 Clearly bearings first if you have to do it that way, for damage limitation. Quote Link to comment Share on other sites More sharing options...
