Urgent Help needed!!!!
sfield21
Hello, I'm not sure whether this is in the right forum area however I need some help as my drivers headlight has begun taking in water resulting in the xenon bulb blowing , I've assumed ill need a new headlight as changing the bulb would just be pointless whilst exposed to the water , can someone help me on this situation and where I can find an OEM HID drivers headlight for an 05 , the urgency is I have my MOT coming up !!
Your help will be much appreciated :teeth:
Nice one Loen :thumbs:
I should be able to help you with a replacement headlamp. :thumbs:
The ballast may also be damaged due to ingress of water.
Most common reason for this type of failure is peeps running without the inner front wheel arch liner.
Liners and fixings also in stock if required.
Drop me a PM if I can help you further :thumbs:
Alex :)
