SteveW Posted June 22, 2012 Share Posted June 22, 2012 Part number 1, more to follow: Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted June 22, 2012 Share Posted June 22, 2012 Nice work, Steve... Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted June 22, 2012 Share Posted June 22, 2012 That looks great... before you know it you will be wrapping all the stuff in your house Quote Link to comment Share on other sites More sharing options...
coldel Posted June 22, 2012 Share Posted June 22, 2012 A rocky road you are on there my friend - I went wrap crazy this week, a little sneak preview... ...and I didnt stop there! Quote Link to comment Share on other sites More sharing options...
onthatB0MBSHELL Posted June 22, 2012 Share Posted June 22, 2012 wow, looks good. your before handles look like mine do now Quote Link to comment Share on other sites More sharing options...
14N Posted June 22, 2012 Share Posted June 22, 2012 Good work my friend. Quote Link to comment Share on other sites More sharing options...
SteveW Posted June 22, 2012 Author Share Posted June 22, 2012 This was way harder and didn't get the window switch how I wanted so will redo when I have more experience.. Quote Link to comment Share on other sites More sharing options...
14N Posted June 22, 2012 Share Posted June 22, 2012 You've seen my attepts at this Steve. The passenger one is much easier than the driver's one. Keep practising mate. Drop me a PM if needed and I can maybe help you out. Quote Link to comment Share on other sites More sharing options...
wackosr Posted June 22, 2012 Share Posted June 22, 2012 Liking the look of the door handle. Have been compemplating a wrap v smoothing a painting. Drivers side is quite a state! Quote Link to comment Share on other sites More sharing options...
SteveW Posted June 22, 2012 Author Share Posted June 22, 2012 Cheers I4N it was much easier. Done the drivers one as well now, will probably have another go at it though because I think I was expecting the vinyls could do too much and ripped it going the hand grab. It still looks good might just need a lil touch up. Quote Link to comment Share on other sites More sharing options...
SteveW Posted June 22, 2012 Author Share Posted June 22, 2012 Now if only I could work out how to get the silver steering wheel inserts out..... Bloody lacquer has got a right peel on! Quote Link to comment Share on other sites More sharing options...
coldel Posted June 22, 2012 Share Posted June 22, 2012 I am one step ahead of you steve! I wanted to wrap the two silver inserts but it does mean taking the steering wheel off to get at bolts on the back. You will need to disconnect the battery and pump the brake to clear the power completely to stop any air bag action! Quote Link to comment Share on other sites More sharing options...
14N Posted June 22, 2012 Share Posted June 22, 2012 The hand grab was the difficult bit. I used a couple of pieces on mine, with a very slight overlap on the top edge which can't really be seen once you've finished.. This maybe difficult to explain via text, but here goes (bear with me). If you look at the grab handle from above, with the 2 longer sides on the left and right (shorter edges top and bottom). I wrapped the top, left, bottom (and very bottom) of the grab handle first and cut around the top edge, just so it overlapped onto the top surface by a few mm. I did this first before applying the 'main' wrap. With the main piece in place, I then cut the opening for the handle on the 3 sides I'd previously wrapped, leaving a wrap 'flap' attached to the right hand side (facing you when in the car). I then used this to cover the remaining side of the handle. You can just make out the join in this pic. Hope this helps a little Steve. I'm no expert and I wouldn't claim it was a brilliant job, but I'm happy with the result. Quote Link to comment Share on other sites More sharing options...
SteveW Posted June 22, 2012 Author Share Posted June 22, 2012 Yes mate that does help, thank you! I was trying to work out how you did yours from your earlier pic, what you say makes perfect sense, that's just what I need to do to mine put an infill piece in then it will be spot on. Thanks again! Quote Link to comment Share on other sites More sharing options...
SteveW Posted June 22, 2012 Author Share Posted June 22, 2012 By the way liking the red Coldel!!! Wrapping is addictive! Quote Link to comment Share on other sites More sharing options...
14N Posted June 22, 2012 Share Posted June 22, 2012 No worries buddy. Really glad it helped Quote Link to comment Share on other sites More sharing options...
glrnet Posted June 22, 2012 Share Posted June 22, 2012 Good first time effort Steve Quote Link to comment Share on other sites More sharing options...
