Different specs of JDM
nixy
but essentially all have at least traction control which was my worry so that's ok.
careful as this was a discussion point on here a while back, there's quite a few different codes for the driver aids, traction control, esp, vdc and possibly another one which i can't remember.
Lomoto did a little research into this in that thread, tim, you remember where it was?
I cant find it either ??? :headhurt:
JDM Specs
Base---17" wheels, ABS,Brake assist,TCS,xenon headlights don't think it has LSD, the base US one hasn't got it
Version T---- leather seats, seven speaker bose (LSD I think)
Version S-- 18" rims Brembo's and VDC (in addition to TCS)but no leather (LSD I think)
Version ST--leather +Version S spec
rear spoilers/sat nav and side airbags ordered as extras on all specs + loads of other Extras not seen on UK cars like auto fold mirrors ,different steering wheels, footwell illumination etc etc...
think the above is nearly correct, in bold my additions
JDM Specs
no base models have LSD, well mine has anyway :)
a minefield of acronyms, why does every manufacturer have to make their own special name for essentially the same systems... :rant::headhurt:
Antilock Braking Systems
Traction Control Systems
Active Yaw Control Systems
ABS (Anti-lock Braking System)
ASC (Automatic Stability Control)
RWAL ASR Active Handling
(Rear Wheel Anti-lock) (Automatic Stability Regulation)
SCS Brake Only Traction Active Safety
(Stop Control System)
ETS (Enhanced Traction System) Advance Traction
TCS (Traction Control System)
ASMS (Automotive Stability Management System)
TCB (Traction with Brake Int.)
ATTS
CBC (Cornering Brake Control)
DSC (Dynamic Stability Control)
DTSC (Dynamic Stability and Traction Control)
ESP (Electronic Stability Program)
ICCS (Integrated Chassis ControlSystem)
IVD (Integrated Vehicle Dynamics)
PCS (Precision Control System)
PSM
SCS (Stability Control System)
StabiliTrac
Traxxar
VDC (Vehicle Dynamics Control)
VSA (Vehicle Stability Assist)
VSC (Vehicle Stability Control)
YCS (Yaw Control Stability)
So TCS is on all models inc the T version (which is mine) - but LSD ????? What's this when it's at home??? I don't have a button for this on mine unless it's under the seat somewhere?
Limited slip differential. It's mechanical so there's no on/off switch. :)
