philb1965 Posted June 11, 2012 Share Posted June 11, 2012 Booked in with Northampton motorsport for a 4 wheel alignment on the 23rd. The rear wheels are wearing on the outers when they should have negative camber. Readings for tread depth are inner 5mm outers 2mm. This is on 18k mainly dual carriageways. It will be interesting to see what the readings are. Wrong from manufacture is my guess. Quote Link to comment Share on other sites More sharing options...
philw99 Posted June 11, 2012 Share Posted June 11, 2012 Mine needs doing as well same issue, outside edge of the rear Quote Link to comment Share on other sites More sharing options...
philb1965 Posted June 11, 2012 Author Share Posted June 11, 2012 Mine needs doing as well same issue, outside edge of the rear Hopefully worth the money with the cost of tyres. Quote Link to comment Share on other sites More sharing options...
ScottyZ Posted June 11, 2012 Share Posted June 11, 2012 Booked in with Northampton motorsport for a 4 wheel alignment on the 23rd. The rear wheels are wearing on the outers when they should have negative camber. Readings for tread depth are inner 5mm outers 2mm. This is on 18k mainly dual carriageways. It will be interesting to see what the readings are. Wrong from manufacture is my guess. That's where I'll be going when I get the car lowered. Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 11, 2012 Share Posted June 11, 2012 It will be interesting to see what the readings are. Wrong from manufacture is my guess. After 18K miles, how would you know? OEM specs are very generous anyways, always best to take it to a specialist who can set the car up for your style, rather than just get it in the green Quote Link to comment Share on other sites More sharing options...
philb1965 Posted June 11, 2012 Author Share Posted June 11, 2012 It will be interesting to see what the readings are. Wrong from manufacture is my guess. After 18K miles, how would you know? OEM specs are very generous anyways, always best to take it to a specialist who can set the car up for your style, rather than just get it in the green To be honest it's all dual carriageway, 25 miles each way, so I guess driving style doesn't come into it to much. The only thing I can say is I must be fairly easy on the loud pedal to get 18k + out of the tyres anyway. I just want to get t sorted before I buy some new tyres or trash my spare set. Quote Link to comment Share on other sites More sharing options...
Ekona Posted June 11, 2012 Share Posted June 11, 2012 It really means you're not driving it properly Quote Link to comment Share on other sites More sharing options...
philb1965 Posted June 11, 2012 Author Share Posted June 11, 2012 It really means you're not driving it properly Yep I know...does do 120 in 4th gear...I believe I need to rag it a bit more off the line. Quote Link to comment Share on other sites More sharing options...
