B3n5253 Posted June 2, 2012 Author Share Posted June 2, 2012 vid of my noise Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted June 2, 2012 Author Share Posted June 2, 2012 hi mrt that explains mine perfectly! only a nise on way down not up. sounds not 2 bad to fix thanx Quote Link to comment Share on other sites More sharing options...
mrt Posted June 2, 2012 Share Posted June 2, 2012 Well if it is the problem it,s a cinch to fix.. and cheap ! Let me know if i,m correct will you ? roger Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted June 2, 2012 Author Share Posted June 2, 2012 Will do mte! Just have 2 get the other noise sorted, lol! Quote Link to comment Share on other sites More sharing options...
sunshine Posted June 2, 2012 Share Posted June 2, 2012 vid of my noise I'm pretty sure it's the same problem as mine mate, do you get the same noise in gear when driving? Almost like a supercharged sound? I'm replacing both the release bearing and the input bearing because i can't distinguish which one it is, there both worn so I'm playing it safe. Good news is it's not going to fail anytime soon, I've had my zed over a year and done over 10000 miles with no problem, the only reason im sorting it out is because my clutch needs doing anyway, but if the garage is doing it for you anyway then get it done Good luck getting it sorted mate and like I said I'll let you know next week if I've sorted it Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted June 2, 2012 Author Share Posted June 2, 2012 That's good was worried it could go any minute! Not sure about it when driving in gear. Hope it solves your problem mte. I'll let you know how mine goes 2! Hopefully we should both be fixed soon :-) ! Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted July 5, 2012 Author Share Posted July 5, 2012 Had the repair report for the gearbox back for the noise when the clutch is up in neutral. The following parts were replaced. 1st motion bearing X2 lay gear bearings The guy also said that there will always be a noise as its a characteristic of this gear box but mine was too loud to just be a characteristic nose and there was a fault. Hope this helps anyone also experiencing this problem Quote Link to comment Share on other sites More sharing options...
jell36 Posted July 5, 2012 Share Posted July 5, 2012 Had the repair report for the gearbox back for the noise when the clutch is up in neutral. The following parts were replaced. 1st motion bearing X2 lay gear bearings The guy also said that there will always be a noise as its a characteristic of this gear box but mine was too loud to just be a characteristic nose and there was a fault. Hope this helps anyone also experiencing this problem So was this a full gearbox strip down and replace? How much did it cost and how long did it take? Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted July 5, 2012 Author Share Posted July 5, 2012 The company I bought it from put it in to be fixed so not sure on cost or time. It was a full gearbox out and strip to fix fault. I posted a vid earlier on. I guess if you have the noise then u will just have too judge how loud it is and if you have a problem or not Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted July 5, 2012 Share Posted July 5, 2012 Doubtful a warranty would cover a clutch as it would be classed as wear and tear, personally I would try the garage and see if they will maybe do the work if you supply the parts Quote Link to comment Share on other sites More sharing options...
