B3n5253 Posted May 31, 2012 Share Posted May 31, 2012 Hi everyone! Picked it up 2day! Love the car! I have one small problem though! When you press the clutch in there is a sort of knocking/klunking noise! Only when the pedal is pressed down and not on the way up! Anyone have this 2 or have any idea what it is? Any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted May 31, 2012 Author Share Posted May 31, 2012 Sorry about the duplicate pic Quote Link to comment Share on other sites More sharing options...
sunshine Posted May 31, 2012 Share Posted May 31, 2012 Hi welcome, no way to sugarcoat this but the clutch release bearings knackard. Hope you knocked the seller down about £600 for the new clutch/flywheel fitting your gonna require very soon. Hope you get it sorted Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted May 31, 2012 Author Share Posted May 31, 2012 Thanks for the reply! Oh dear :-( ! Does this have 2 be done straght away? Quote Link to comment Share on other sites More sharing options...
Zugara Posted May 31, 2012 Share Posted May 31, 2012 and yep Quote Link to comment Share on other sites More sharing options...
Keyser Posted May 31, 2012 Share Posted May 31, 2012 Sounds like a release bearing If you have no warranty for the parts Quote Link to comment Share on other sites More sharing options...
Humpy Posted May 31, 2012 Share Posted May 31, 2012 Welcome to the forum and pleased to hear your enjoying the car, sorry to hear about your problems though with the clutch. Sascron cars by the looks of that Garage, always having a nosey at their cars, have some amazing cars in their showroom Quote Link to comment Share on other sites More sharing options...
sunshine Posted May 31, 2012 Share Posted May 31, 2012 I wouldn't leave it mate, i had the same symptoms in my last car and left it.... Release bearing collapsed in rush hour traffic on a busy roundabout ... It may be okay for a bit, try not using the clutch much, i.e stick it in neautral at traffic lights. Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted May 31, 2012 Author Share Posted May 31, 2012 Yes was from sascron. Did have some lovely cars! I have 3star AA extended warranty with the car for 3months! Anyone know if it will cover it? Also sounds like when the clutch Is up there is slight sound change from under the bonnet! Sounds better with the clutch down! Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted May 31, 2012 Author Share Posted May 31, 2012 What parts would I need replaced? Just the release bearing? Or clutch and release bearing? Or anything else, lol! Quote Link to comment Share on other sites More sharing options...
Mikesding Posted May 31, 2012 Share Posted May 31, 2012 This doesn't sound good! I heard a similar noise on my new 350z. Will have to listen again tomorrow Quote Link to comment Share on other sites More sharing options...
KyleR Posted May 31, 2012 Share Posted May 31, 2012 You only picked it up, and it was bought from a dealer, right? Then you have the right to bring it back and have it repaired as it's not fit for it's intended use according to the Sales of Goods act of 1979. Get down to the dealer ASAP! Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted June 1, 2012 Author Share Posted June 1, 2012 I'll be ringing the dealer 2day! I also have had an EML light come on! How should I explain 2 the dealer the problem with the clutch? It has the klunking noise when pushing down and also when the clutch is lifted up on neutral there is a sound from the front, like somthing changes pitch! All gears select fine though and pulls of ok! Quote Link to comment Share on other sites More sharing options...
KyleR Posted June 1, 2012 Share Posted June 1, 2012 Just tell him the release bearing has gone due to the noise it's making, he should know that you're most likely right. Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted June 1, 2012 Author Share Posted June 1, 2012 Ok thanks! What about the louder noise when I bring the peddle back up? Quote Link to comment Share on other sites More sharing options...
Keviswatt Posted June 1, 2012 Share Posted June 1, 2012 Get it back to the dealer. Nice looking motor Q K Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted June 1, 2012 Author Share Posted June 1, 2012 Thank for all the help! I'll be ringing them 2day Quote Link to comment Share on other sites More sharing options...
Mikesding Posted June 1, 2012 Share Posted June 1, 2012 Mine has this noise when I put it on neutral and let the clutch up. Is this going to be the release bearing too? Quote Link to comment Share on other sites More sharing options...
C.J Posted June 1, 2012 Share Posted June 1, 2012 Ok thanks! What about the louder noise when I bring the peddle back up? I wouldn't worry about this. Afaik this is common with the 350, it's the flywheel sound. Sounds like a rattle or grind when the peddle is up. Should only be a slight change in sound though. Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted June 1, 2012 Author Share Posted June 1, 2012 Have had a deeper look into finding the noise when pressing the clutch down! It seems to be coming from right next 2 the pedal! Think it may be the big red spring connected 2 it! Any ideas? Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted June 2, 2012 Author Share Posted June 2, 2012 Hi everyone! Iv spoken 2 the dealer and they have agreed to fix all the faults with the car! Found out the fault code! - P2a03 ! I beleve this is a lambda sensor fault! Am I correct?? The noise when pushing down the clutch is from the red damper spring. If you hold the spring and press the clutch the noise goes away! With the car stared and in neutral with the clutch down the car sounds fine! When you bring up the clutch the car kinda make a higher pitched noise! The mechanic said it sounds v much like the clutch release bearing! Can anyone confirm this?? Quote Link to comment Share on other sites More sharing options...
fish1471 Posted June 2, 2012 Share Posted June 2, 2012 yes release bearing i think..... Quote Link to comment Share on other sites More sharing options...
sunshine Posted June 2, 2012 Share Posted June 2, 2012 Hi everyone! Iv spoken 2 the dealer and they have agreed to fix all the faults with the car! Found out the fault code! - P2a03 ! I beleve this is a lambda sensor fault! Am I correct?? The noise when pushing down the clutch is from the red damper spring. If you hold the spring and press the clutch the noise goes away! With the car stared and in neutral with the clutch down the car sounds fine! When you bring up the clutch the car kinda make a higher pitched noise! The mechanic said it sounds v much like the clutch release bearing! Can anyone confirm this?? Hi mate, do you mean like this? If so you have the exact problem as me. I've got the gearbox off at ghe minute. I noticed some high pitched noise from the release bearing when no load is on it that dissapears when its pressed down, but im not confident that in the noise i'm experiancing. I have however noticed a load of play in the input shaft, mainly because the front input shaft bearings are shagged. I'm currently waiting on the replacement input bearing, front case gasket and pilot bushing from nissan (stupid bank holidays) I'll let you know how it goes, needless to say i'll be pi**ed if its not cured it, cost £600ish so far. Quote Link to comment Share on other sites More sharing options...
B3n5253 Posted June 2, 2012 Author Share Posted June 2, 2012 Hiya mte! Yours seems a lot louder than mine I think. I'll try and get a vid if I can and post up for I 2 listen 2! Quote Link to comment Share on other sites More sharing options...
mrt Posted June 2, 2012 Share Posted June 2, 2012 Good news maybe ! I had exactly the same problem with my 07 Zed. There is a spring at the bottom of the clutch pedal which became slightly twisted on mine. Approx two thirds down the thing clunked but didn,t clunk on the way back up. Nissan replaced the pedal assembly on mine under warranty but they could have just replaced the spring which had become bent. Hope that,s the problem. regards Roger Quote Link to comment Share on other sites More sharing options...
