Keviswatt Posted May 30, 2012 Share Posted May 30, 2012 Have a knock coming from front end as I posted on another thread..Got under the car today for a look.and can't see anything oviously wrong with the suspension. Have however discovered that the knock does not happen in reverse . Does this point to compression arm bush/ball joint? Cheers in advance Kev Quote Link to comment Share on other sites More sharing options...
Ebized Posted May 30, 2012 Share Posted May 30, 2012 Moved from 370 section, unless you have changed your car recently Quote Link to comment Share on other sites More sharing options...
Keviswatt Posted May 30, 2012 Author Share Posted May 30, 2012 Moved from 370 section, unless you have changed your car recently Oops! Sorry! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 30, 2012 Share Posted May 30, 2012 Kev, If the compression rod bush has failed then it would be obvious to the traned eye mate. Other areas are compression rod ball joint, suspension upright lower ball joint, sway bar drop links. etc.etc.etc. I have all the above in stock and good to go same/next day if required. Drop me a PM if I can help you further mate Alex Quote Link to comment Share on other sites More sharing options...
