LordGrover Posted May 30, 2012 Share Posted May 30, 2012 Since my clutch and flywheel were replaced last year, fifth & sixth have been a little notchy or difficult to select. Yesterday, I couldn't select either. I'd assumed there is an H-plate or guide on the top of the box which is misaligned but I now think that's not right. After a bit of experimentation, I discovered pressing the stick a la reverse gear allows easy selection of both fifth & sixth. Any ideas peeps? Is it safe to pop it into local Nissan dealer and not get screwed over? Quote Link to comment Share on other sites More sharing options...
Ebized Posted May 30, 2012 Share Posted May 30, 2012 Since my clutch and flywheel were replaced last year, fifth & sixth have been a little notchy or difficult to select. Yesterday, I couldn't select either. I'd assumed there is an H-plate or guide on the top of the box which is misaligned but I now think that's not right. After a bit of experimentation, I discovered pressing the stick a la reverse gear allows easy selection of both fifth & sixth. Any ideas peeps? Is it safe to pop it into local Nissan dealer and not get screwed over? I would suggest you use a good independent who know the 350's - chances are the Nissan dealer will not have any techies who know their way around the ZEDs. I am sure those more local to you in Bristol can point in the right direction but the nearest Trader on here I am aware of and who I am sure could sort this for you is Jez at Horsham Developments who are at Chievely in Berkshire. http://www.h-dev.co.uk/index2.php?page=home Quote Link to comment Share on other sites More sharing options...
Wasso Posted May 30, 2012 Share Posted May 30, 2012 Since my clutch and flywheel were replaced last year, fifth & sixth have been a little notchy or difficult to select. Yesterday, I couldn't select either. I'd assumed there is an H-plate or guide on the top of the box which is misaligned but I now think that's not right. After a bit of experimentation, I discovered pressing the stick a la reverse gear allows easy selection of both fifth & sixth. Any ideas peeps? Is it safe to pop it into local Nissan dealer and not get screwed over? I would suggest you use a good independent who know the 350's - chances are the Nissan dealer will not have any techies who know their way around the ZEDs. I am sure those more local to you in Bristol can point in the right direction but the nearest Trader on here I am aware of and who I am sure could sort this for you is Jez at Horsham Developments who are at Chievely in Berkshire. http://www.h-dev.co.uk/index2.php?page=home +1 on Horsham Quote Link to comment Share on other sites More sharing options...
coldel Posted May 30, 2012 Share Posted May 30, 2012 Have you actually had the top off the gear stick area to check the alignment? I had a clutch change and had the same problem, a quick check some realignment and hey presto all is well again. Worth check properly as it only takes 10 minutes to pull all the covers off and take a look. Quote Link to comment Share on other sites More sharing options...
LordGrover Posted May 30, 2012 Author Share Posted May 30, 2012 Have you actually had the top off the gear stick area to check the alignment? I had a clutch change and had the same problem, a quick check some realignment and hey presto all is well again. Worth check properly as it only takes 10 minutes to pull all the covers off and take a look. Screwdrivers and spanners send me into a cold sweat. If I can unclip or pull the top maybe I'll take a quick gander when I get back from hols before me op. Otherwise I won't be driving for a few weeks so no biggy if it has to go into the shop for a week or two. Rather save a few quid though if poss. Thanks for the suggestion. Quote Link to comment Share on other sites More sharing options...
coldel Posted May 30, 2012 Share Posted May 30, 2012 http://www.350z-uk.com/forum/viewtopic.php?f=35&t=52351&start=0 In case you do fancy a go at it - looks complex in the instructions but once you take off the cover its all quite nicely laid out and intuitive. Quote Link to comment Share on other sites More sharing options...
LordGrover Posted May 30, 2012 Author Share Posted May 30, 2012 Nice one mate. I've saved it as a PDF for easy printing: click. Quote Link to comment Share on other sites More sharing options...
Bockaaarck Posted May 30, 2012 Share Posted May 30, 2012 Wonder if it's worth having a word with the guys at FCM in Bristol? They specialise mainly in Evo's / Subari's but are one of the traders here on the forum and have done some good work on my Zed. Quote Link to comment Share on other sites More sharing options...
LordGrover Posted May 30, 2012 Author Share Posted May 30, 2012 Yep. John's serviced my Zed the last two times, very happy with them. Just a bit awkward getting there for such a relatively simple job though. I'll have a try with coldel's guide. Quote Link to comment Share on other sites More sharing options...
Freebird Posted May 30, 2012 Share Posted May 30, 2012 Id go with what coldel said first, takes a few mins max to realign the plate on top of the gearbox. Quote Link to comment Share on other sites More sharing options...
Fodder Posted May 30, 2012 Share Posted May 30, 2012 Interesting, I had mine swapped out about 1k ago now and noticed the same at times. Wasnt sure if it was me or something else but the OH has also noticed it too and had been meaning to get the linkage alignment checked. The guide looks very simple so will give it a bash at the weekend. Thanks Coldel and I hope it fixes your issue too LordGrover Quote Link to comment Share on other sites More sharing options...
