PCV Valve
Posidrive
Before trotting off to get my oil consumption/smoking investigated by a pro I thought I'd clutch at straws and check the PCV valve. Is this a DIY job, how long should it take. Can you get to it from the engine bay?
If the PCV valve is knackered where is the best place to get a replacement. The Nissan dealer near where I work has a bit of a reputation so I'd like to avoid if possible.
It is located in the cam cover on the top of the engine and is easily reached and is a DIY and will only take a few minutes.
New and preowned PCVs in stock if required :thumbs:
Alex :)
Alex :)
Thanks, wiill get back to you if its knackered. Hope it is.....
