john smith Posted May 27, 2012 Share Posted May 27, 2012 ive had the 19 inch volks on for a while now, fitted with a 15mm spacer, problem is the wobble i had them balanced and no difference,so i assumed the garage hadnt done it right ive been really busy so i only got round the other day to getting them done again. this time he spenet ages and to test a theory he put weights on the outside too any way its not much better, ????? anyone else had the problem ? i am going to try with the old rays on , but if anyones got any suggestions i would be grateful. Quote Link to comment Share on other sites More sharing options...
planetsurfer2 Posted May 27, 2012 Share Posted May 27, 2012 Do you mean the wheels are balanced, but the wheels wobble on the car? Is it all wheels or just one? Quote Link to comment Share on other sites More sharing options...
Zugara Posted May 27, 2012 Share Posted May 27, 2012 I recon the pcd on the spacers is not concentric with the centre of the spacer, giving you an elliptical diameter from the pcd diameter to the diameter of the spacer. Else the spacer ain't machined correctly and in warped. Quote Link to comment Share on other sites More sharing options...
Martin S Posted May 27, 2012 Share Posted May 27, 2012 I would look carefully at the tyres first. Jack up each corner, spin the wheels and check for bulges. I've know a few cars that have had a 'wobble' and it's turned out to be an oval tyre. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted May 28, 2012 Share Posted May 28, 2012 As they have been balanced twice, I would assume that if the tyre was bulging or the wheel was out of shape you would have seen it on the balancing machine. So I would suspect the spacers. Take them off and try without, make sure your hub is very clean so it all goes on square and make sure you have the correct size hubcentric rings fitted for your wheel/hub combo. If its none of the above, do you feel it more when braking? Could be warped brake discs. Quote Link to comment Share on other sites More sharing options...
Ebized Posted May 28, 2012 Share Posted May 28, 2012 viewtopic.php?f=182&t=62233 Sorted out my problem that turned out to be added spacers Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 28, 2012 Share Posted May 28, 2012 shouldnt be putting weights on the outside. I'd try another garage I'd also check if the wheels are bent, what make are the spacers? Is the wobble under braking or all the time. Quote Link to comment Share on other sites More sharing options...
john smith Posted May 29, 2012 Author Share Posted May 29, 2012 cheers for replies, he only put the spacers on outside to try it, hes a mate. i will look at what youve said guys thanks Quote Link to comment Share on other sites More sharing options...
