Clutch Adjustment Advice
uk850t5
Hi All,
Can anyone provide any further comments on this mod
viewtopic.php?f=35&t=52268
I tried it and can confirm the car is easier to drive (gear change) as now i idont have to float my foot in the air at biting point - so smoother takeoff & gear change
However, reading further into this, the pedal is now completly out of nissan spec as per;
http://www.competitionclutch.com/tech/PUB-6072-1.pdf - not sure if this is even for a 2008 350z
If i release the Clutch i have slight play at the top before it engages, not sliping when i cnage gears - but am i doing any damage by running this mod? I'm worried its disengaging the clutch but still ringing the thrust bearing - if that makes sence
Advice appreciated.
Thanks (noob Zed owner)
A bit of free play is normal, confirmed by the link you posted. Measure it to make sure it's within limits of 9-11mm. I've had the same bit of play you're talking about for about 1000 miles and no problems to report.
