Dizzy007 Posted May 25, 2012 Share Posted May 25, 2012 I have had the car for about a month now, got in it today and noticed a couple of things, first the clutch biting point is right at the bottom of the pedal and I stalled it, also I thought that selecting the gears seemed a bit notchy, could this be related and do I have a serious problem, the car still has some warranty left on it Quote Link to comment Share on other sites More sharing options...
sunshine Posted May 25, 2012 Share Posted May 25, 2012 Sounds to me like your clutch fluid is leaking, try bleeding it first. Quote Link to comment Share on other sites More sharing options...
Roo Posted May 25, 2012 Share Posted May 25, 2012 Have you checked clutch fluid? normal complaint is its too high! Some people have commented that changing gearbox oil helps smoothness also. Quote Link to comment Share on other sites More sharing options...
Zugara Posted May 26, 2012 Share Posted May 26, 2012 Get the garage to check it out Quote Link to comment Share on other sites More sharing options...
speedwell Posted May 26, 2012 Share Posted May 26, 2012 Clutch low...usually a hydraulic system fault,in master or slave cylinder,which is confirmed if fluid is being lost. Clutch high..worn out! Either way,seems like a garage job,as already said. Quote Link to comment Share on other sites More sharing options...
Dizzy007 Posted May 26, 2012 Author Share Posted May 26, 2012 Got in car at lunch, clutch pedal still at the floor and biting at the bottom, pulled the pedal up, pumped it and it's now back to normal, fluid level is still ok, could this be slave cylinder, thanks for all the replies Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 26, 2012 Share Posted May 26, 2012 Got in car at lunch, clutch pedal still at the floor and biting at the bottom, pulled the pedal up, pumped it and it's now back to normal, fluid level is still ok, could this be slave cylinder, thanks for all the replies New Slave cyl + braided clutch line + new high temperature clutch fluid will fix your issue All parts in stock and good to go same/next day Drop me a PM if I can help you further Alex. Quote Link to comment Share on other sites More sharing options...
