Keviswatt Posted May 19, 2012 Share Posted May 19, 2012 Hi all! Have had an annoying knock coming from the front of the Z for a while now, for a start it seemed to be coming from the passenger side but now seems to be knocking at both sides. I have had a local garage look at it twice now an couldnt find any obvious worn bush's etc. The knock is only really visible at low speeds but is quite loud Any usual suspects i should check? cheers Kev Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted May 19, 2012 Share Posted May 19, 2012 It'll probably be ARB drop links or compression arm ball joints. Both in stock and ready to go, when you know exactly whats up Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 19, 2012 Share Posted May 19, 2012 Hi all! Have had an annoying knock coming from the front of the Z for a while now, for a start it seemed to be coming from the passenger side but now seems to be knocking at both sides. I have had a local garage look at it twice now an couldnt find any obvious worn bush's etc. The knock is only really visible at low speeds but is quite loud Any usual suspects i should check? cheers Kev Hi Kev, Drop Links: Compression rod bushes: Compression rod ball joints: Hub carrier lower ball joints: These are the 4 most common, in particular the compression rod bushes and ball joints. All in stock and good to go same/next day if required mate:thumbs: Alex. Quote Link to comment Share on other sites More sharing options...
Zugara Posted May 19, 2012 Share Posted May 19, 2012 Banana bar Quote Link to comment Share on other sites More sharing options...
Zugara Posted May 19, 2012 Share Posted May 19, 2012 viewtopic.php?f=59&t=61405 Quote Link to comment Share on other sites More sharing options...
