Changing a reverse light bulb?
andrewsin
Hi all,
My reverse doesn't work and also at the same time my rear Parking sensors dont work either....anyone know how to change the reverse light bulb? Would you think the parking sensors will come back on after?
Thank you
Andrew
I was hoping I could just change the bulb and the sensors will come back on! I've booked a service with Nissan and they said they will have a look into this hope it's not going to cost a fortune! But die anyone know how to change the bulb and which bulb to get so ican try fix it without being charged from Nissan?
Thanks
Take the tail light unit out which affords a gap to access the rear of the indicator/reverse light unit. Unlikely to fix your sensor problem, more likely the switch as above, did they go at the same time?
If you have a hand book all this info on bulbs and changing is in there.
