chocohercules Posted May 15, 2012 Share Posted May 15, 2012 Hi another quicky, If the driverside Camsensor is disconnected or taken off the car, should the car be running as normal or would it cause the car to run poorly or not start at all? As mine has been taken off the car and still starts and drives, but disconnected the pasengerside and it wouldnt fire up gave up after 5 secs!! surely it should affect the car in the same way on the driverside? Quote Link to comment Share on other sites More sharing options...
Neilp Posted May 15, 2012 Share Posted May 15, 2012 Have you had a garage fit this new engine? Seems like a never ending problem story? Sorry I can't help you with the info you need. Quote Link to comment Share on other sites More sharing options...
Zugara Posted May 15, 2012 Share Posted May 15, 2012 Would have thought it would throw a code, or stop the engine tbh. Quote Link to comment Share on other sites More sharing options...
chocohercules Posted May 19, 2012 Author Share Posted May 19, 2012 Ok Zugara makes sense I will take it off and get it diagnosed if there is a new code then it works if there is no new code and still shows as P0335 crank position sensor then may be causing my issue? Quote Link to comment Share on other sites More sharing options...
