chocohercules Posted May 12, 2012 Share Posted May 12, 2012 More investigation work! I love tinkering!!...... I have just noticed when I disconnect the passengerside cam sensor! The car won't start......but when I start the car with the driverside cam sensor disconnected it starts and drives like normal (well in its currently poor running state? Is this normal? It was also covered In oil is this right too? Shouldn't the car start with either one of these sensors disconnected or is it normal? Cheers Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 12, 2012 Share Posted May 12, 2012 Could be down to being faulty, have you checked codes P0340 and P0345. Quote Link to comment Share on other sites More sharing options...
chocohercules Posted May 12, 2012 Author Share Posted May 12, 2012 That's what I'm now thinking as I took the sensor out and car starts and drives like normal with the sensor not even on the car? apart from the rough running that my car has! Surely if the sensor is off the car it should run even worse? Haven't checked them codes as I get P0335 crank position sensor. This has been changed still got my problems???could a dodgy cam sensor throw different codes and point to something else? Quote Link to comment Share on other sites More sharing options...
keiichi tsuchiya Posted November 29, 2012 Share Posted November 29, 2012 hi, i have this error P0345 cel where i can buy online this part and send to italy (my home)??? have you know any secure site for this parts? Quote Link to comment Share on other sites More sharing options...
bronzee Posted November 30, 2012 Share Posted November 30, 2012 hi, i have this error P0345 cel where i can buy online this part and send to italy (my home)??? have you know any secure site for this parts? Probably from Zmanalex on here. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 30, 2012 Share Posted November 30, 2012 Thank you bronzee Sensors for DE and HR in stock and good to go same/next day. Just drop me a PM if I can help you further. Alex. Quote Link to comment Share on other sites More sharing options...
Keyser Posted November 30, 2012 Share Posted November 30, 2012 That's what I'm now thinking as I took the sensor out and car starts and drives like normal with the sensor not even on the car? apart from the rough running that my car has! Surely if the sensor is off the car it should run even worse? Haven't checked them codes as I get P0335 crank position sensor. This has been changed still got my problems???could a dodgy cam sensor throw different codes and point to something else? Yes the car will start and run without the drivers side crank sensor in (when I was trying to get a Zed started we were swapping sensors from another Zed and found this out) I don't recommend it though as it won't be able to monitor VVT! The reason it won't start with the passenger side crank sensor out is because it uses this one along with the crank position sensor for timing so if that one is out the coil packs won't fire (or at least not in time) Faulty crank position sensors can give some random errors and cause rough idle and running as can a damaged flywheels (the keyway on the back is used by the crank sensor for timing) as this is part of the baseline timing for the engine. This is all from personal experience that tracked back to a faulty crank sensor - this can be found on the front edge of the gearbox near the clutch slave cylinder (assuming a VQ35DE engine) Quote Link to comment Share on other sites More sharing options...
