Dano190485 Posted May 12, 2012 Share Posted May 12, 2012 hi ive recently brought some new wheels and the front looks good but the rear looks like its sitting to high. so ive done some research and alot of you say it looks lower if you use spacer, so ive decided to try that route. but im worried about rubbing. the wheels i have put on are 19" x 9.5 and et40 the tyres are 265/30 so would i get away with 20mm spacers with out rubbing and will they help with filling the arches. thanks any advice will be good Quote Link to comment Share on other sites More sharing options...
Gudzy Posted May 12, 2012 Share Posted May 12, 2012 Using this site: http://www.1010tires.com/wheeloffsetcalculator.asp they stick out 6mm more than rays as standard. Most people suggest a 25mm spacer on the back with rays so a 20mm spacer sounds like it would be ideal. Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted May 12, 2012 Share Posted May 12, 2012 My suggestion would still be the same as the last time you asked here - viewtopic.php?f=61&t=61355&p=881247#p881247 Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted May 12, 2012 Share Posted May 12, 2012 Also, as your tyre has a profile of 30 this too will also make the gap between the tyre and arch bigger, normally a profile of 35 is used when fitting 19" wheels... Quote Link to comment Share on other sites More sharing options...
