Bosco Posted May 11, 2012 Share Posted May 11, 2012 Hi, I am having 4 rear parking sensors fitted on Monday. Is it possible for them to be installed with the removal of the rear bumper. It look like if you remove the rear tail light and the spare wheel, you maybe be able to pass the wires through the centre grommet. If you have installed rear parking sensors without the removal of the bumper, can you let me know how you accomplished it. Thanks Quote Link to comment Share on other sites More sharing options...
un1eash Posted May 11, 2012 Share Posted May 11, 2012 Yes its possible to do without removing the rear bumper, would be much easy to remove it though which is really easy. Quote Link to comment Share on other sites More sharing options...
un1eash Posted May 11, 2012 Share Posted May 11, 2012 How to remove bumper... http://www.350z-tech.com/wiki/index.php ... er_Removal Quote Link to comment Share on other sites More sharing options...
Bosco Posted May 11, 2012 Author Share Posted May 11, 2012 Thanks for that. What is the procedure, if you don't remove the bumper? Quote Link to comment Share on other sites More sharing options...
un1eash Posted May 11, 2012 Share Posted May 11, 2012 Mask up and mark where to drill holes. Drill holes, you may have to drill through the foam behind aswell. Place sensors in bumper and run cables to left of car, could be difficult as access from top will be limited and foam gets in the way. You will still need to remove the left rear light to gain access to the wiring and gromit into the car. The sensors power comes from the reverse light and you can earth it anywhere. That's pretty much it. It is possible though. Quote Link to comment Share on other sites More sharing options...
Bosco Posted May 12, 2012 Author Share Posted May 12, 2012 Thank you. Quote Link to comment Share on other sites More sharing options...
