piggychu Posted May 9, 2012 Share Posted May 9, 2012 Hi There's wind coming through the driver's window sill when the speed is above 70mph, how can I fix that and where would you guys recommend? Thanks Quote Link to comment Share on other sites More sharing options...
Zugara Posted May 9, 2012 Share Posted May 9, 2012 Assume the window is fully closed? Have you tried a window reset ? Coupe or roadster Quote Link to comment Share on other sites More sharing options...
piggychu Posted May 10, 2012 Author Share Posted May 10, 2012 How to do a window reset ? Quote Link to comment Share on other sites More sharing options...
Zugara Posted May 10, 2012 Share Posted May 10, 2012 Have a look in the guide section Quote Link to comment Share on other sites More sharing options...
DannyBoy Posted May 10, 2012 Share Posted May 10, 2012 when you say window sill, do you mean the top of the window? Mine does this at the moment and in my case it's actually nothing to do with the window, it's a knackered door hinge. It causes the window to sit slightly too low which allows the air pressure to suck it away from the top seal at 65mph+. This makes it whistle, and also leak So yea, before ripping your door apart to get at the window mechanism, just check the hinges for any play, could save yourself some hassle. DB Quote Link to comment Share on other sites More sharing options...
