Silvertec Bulbs ?!?
FUG
anyone purchased and fitted these??
http://www.ebay.co.uk/itm/CHROME-Indica ... 230b4482fe
the little nibs are too big for a snug fit into the 350z bulb holder - dont get that click and they stick out a bit (work fine but dont really like leaving them half hanging out incase they drop into headlamp)
are these the wrong bulbs (silvertec fakes??) or is slight modification needed? (i have tried brute force)
the packaging was also different to these silvertec bulbs off a proper mds website http://www.performancecreations.co.uk/s ... -675-p.asp
little nibs as in bottom left corner are larger on the 'silvertec' bulbs compared to the nibs on the original and so do not click into the holder properly - wrong bulbs or diy needed??
sorry to keep reposting this - currently have the bulbs out and looking for quick answer before it gets dark!!
not sure whether to try modifying the bulbs, perhaps filing the nib down to fit (kinda tricky with the glass bulb) and not sure whether to try get refund. Might even just spray the originals silver, least I know they will fit then!!
Hmm they seemed bright enough once plugged in but were otuside the light unit at that point. The packet says they are not e- marked but there is clearly an E mark on the actual bulb (E8 i think from memory although not sure what EU country that is meant to represent :wacko: ) - legal or not??
i have them on mine too but it didnt stop the police trying to pull half of the wales drive over, shouting that they werent bright enough
+1 i remember the incident well. I ditched mine soon after and got some much better philips one's :blush:
yours were a lot dimmer than mine
Having trawled the forum and finally decided to go for silvatec i have one question about indicator bulbs in general;
How have I ended up buying these:
http://www.ebay.co.uk/itm/CHROME-Front- ... 1105wt_689
When I should have bought these:
http://www.ebay.co.uk/itm/CHROME-Indica ... _798wt_689
Have I totally missed something or is there two variants?
I used various websites, putting in my reg# and I keep getting told 581 Offset pin type indicator bulbs but they are blatantly meant to be the BU582 T20 Capless Wedge type. Normally I can work this stuff out but I'm really stuck :wacko::wacko: lol
Cheers
For ref its a '53 plate
