14N Posted May 9, 2012 Share Posted May 9, 2012 Hi All, Something that's bugging me and each time I wonder if this just affects me/my car, or is a design feature/flaw of everyone else's Zed. Can you open your boot with one hand? Cos I can't I have to depress the boot release button with one hand, whilst pulling the boot open with the other. This is a pain in the bum when carrying something, especially when it's been persisting it down with rain and you don't want to put it down. On all my other cars, once the boot has been opened and/or the button depressed, you've only needed one hand to pull the boot open. This isn't the case on my Zed Am I on my own here, or has anyone else found this? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 9, 2012 Share Posted May 9, 2012 you may require your gas struts to be regassed or you could remove the counterweight in the bootlid Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted May 9, 2012 Share Posted May 9, 2012 Your gas struts may need refilling, you can also take the weight out of the boot lid to make it lighter Damn you and your superior keyboard skills Mike Quote Link to comment Share on other sites More sharing options...
370Ad Posted May 9, 2012 Share Posted May 9, 2012 Or do the 1p trick Quote Link to comment Share on other sites More sharing options...
Southernspeed Posted May 9, 2012 Share Posted May 9, 2012 I had replacement struts, did the penny trick and removed the counter weight. I still wasn't happy so I bought a pair of genuine struts. Problem solved and worth the cost If you do a search you'll find reference to a company called SGS or something like that. Most people seem happy with their struts, but as said, I ended buying new Nissan ones after trying theirs. Quote Link to comment Share on other sites More sharing options...
JackStrong Posted May 9, 2012 Share Posted May 9, 2012 1p trick will do it Quote Link to comment Share on other sites More sharing options...
14N Posted May 9, 2012 Author Share Posted May 9, 2012 Cool, thanks for the prompt responses guys. I assumed my struts were okay, as once my boot was open, it stays open (and doesn't try to eat me) But it would appear that they're not. Right, I'm now off to search for "The 1p trick". How much does this 'trick' cost.....? I'll fetch my coat Quote Link to comment Share on other sites More sharing options...
Geekboy78 Posted May 9, 2012 Share Posted May 9, 2012 i have the same problem... sometimes. doesnt always do it. seems a tiny adjustment in the weight balance would work... so where is the weight in the boot and which way do i have to move it? Quote Link to comment Share on other sites More sharing options...
Geekboy78 Posted May 9, 2012 Share Posted May 9, 2012 found this handy guide... will give it a go. viewtopic.php?t=9903 Quote Link to comment Share on other sites More sharing options...
14N Posted May 9, 2012 Author Share Posted May 9, 2012 Try this, should have everything you/we need viewtopic.php?f=9&t=60584 [EDIT] Dammit you beat me - My fingers were trapped in my boot! Quote Link to comment Share on other sites More sharing options...
Geekboy78 Posted May 9, 2012 Share Posted May 9, 2012 lol - i will be off to halfords to buy the trim tool http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_199487_langId_-1_categoryId_255216 and then have a go at this as soon as the drought is over and we get some dry weather. Quote Link to comment Share on other sites More sharing options...
Geekboy78 Posted May 9, 2012 Share Posted May 9, 2012 it is a slightly unrelated to the boot opening thing, but is still boot related... the barrier that you screw in between the two sections of the boot.... mine is loose on one of the top screws. the plastic bushing (is that the right word?) that slots into the hole belwo the strut and keeps the female screw section into which you screw the, erm, screw has come out. this means i cannot keep it tight and it rattles. i have now decided to take the whole barrier out, but would like to have the option to put it back in. is this a common thing? any simple fix? as will be coming across loud and clear, i am not that technically minded but am very willing! Quote Link to comment Share on other sites More sharing options...
JackStrong Posted May 9, 2012 Share Posted May 9, 2012 Here: viewtopic.php?f=35&t=37034&hilit=penny+trick Quote Link to comment Share on other sites More sharing options...
14N Posted May 9, 2012 Author Share Posted May 9, 2012 Cheers Jack! Quote Link to comment Share on other sites More sharing options...
nzr350z Posted May 9, 2012 Share Posted May 9, 2012 Re 1p trick,i used rubber tap washers,works a treat,one handed opening now. Quote Link to comment Share on other sites More sharing options...
JackStrong Posted May 9, 2012 Share Posted May 9, 2012 Cheers Jack! I had exactly the same problem as you, this is the best fix Quote Link to comment Share on other sites More sharing options...
brumjohn Posted May 10, 2012 Share Posted May 10, 2012 Had similar issue whilst under warranty. Took it to the dealers who said i had an "alignment issue" and not covered by warranty. They suggested 1 hours labour at a £silly/hour. Once i had researched and was going to go through the penny trick, check gassing etc. , I noticed that one of the boot release springs was bent. zmanalex supplied a replacement, no issues since. just worth checking, the dealers didn't spot this. Quote Link to comment Share on other sites More sharing options...
370Ad Posted May 10, 2012 Share Posted May 10, 2012 I just did the penny trick last night, was meaning to do it since i got the car. This thread spurred me one, 2 x 1p in each side and 1 hand opening Best 4p mod ever! Quote Link to comment Share on other sites More sharing options...
14N Posted May 10, 2012 Author Share Posted May 10, 2012 Am I on my own here, or has anyone else found this? Thanks again all, I no longer feel so alone Will hopefully try 1 or 2 of these fixes this weekend if it's dry. Great info and very helpful. You guys rock! Quote Link to comment Share on other sites More sharing options...
14N Posted May 22, 2012 Author Share Posted May 22, 2012 I just did the penny trick last night, was meaning to do it since i got the car. This thread spurred me one, 2 x 1p in each side and 1 hand opening Best 4p mod ever! ^^^^Exactly what 350Ad said above^^^^ Just a bit of feedback/update. Did mine last night with 4p and it works perfectly! Many thanks again Quote Link to comment Share on other sites More sharing options...
