P2135 code! Please help!
spawn
Have you done the resets in order and properly?
It took me about an hour or 2 to do them :rant:
Yes ive done all 3, although the first one is hard to tell if its done anything, because you get no indication of anything, the second one you can hear the flap move, and the third you know has worked when the cel is flashing.
Number 3 it should be flashing then solid. What rpm are you idling at?
Yes then release pedal within 3 secs.
Idling around 800 after reset, when driving and stopping at junctions holds around 1000rpm no higher, the throttle feels kind of weird?
When say your coasting and put your foot on the throttle, it kind of does a soft jerk, it feels like the throttle is abit on and off?? and not smooth?
It may just be a characteristic of the 350z?
Update!
Fitted new (second hand) throttle body, fingers crossed its been fine since! :)
Gave the car a good highspeed run 2nite and no eml light...
So looks like the tps was to blame.
Hopefully i can get on and enjoy the car now :thumbs:
  • 1 year later...
