Goodman50 Posted May 2, 2012 Share Posted May 2, 2012 HI, I have 05 350 roadster GT, If I open the passenger door the window the comes down by about 2cm and shuts when I close the door, I know that is normal, but is it supposed to do the same with the drivers side as that not happening on my car, plus if you just lift and release the the switch to shut the drivers window it will shut all the way and then come down 4" and stop, to close it all the way you have to lift the switch a little bit, hold it like that then let it go after the window is shut, is that normal, cheers Rod Quote Link to comment Share on other sites More sharing options...
M13KYF Posted May 2, 2012 Share Posted May 2, 2012 try a window reset procedure, you can find it in the guides section Quote Link to comment Share on other sites More sharing options...
