DaddyCee Posted May 2, 2012 Share Posted May 2, 2012 Hi All Wondered if someone would be able to advise how to go about removing the following marks from my canvas roof. I believe that this has been caused by the AG roof cleaner product and am hoping that its pretty easy to remove. I have washed the roof with Megs and the marks have returned this morning, they are not that bad but are annoying me more. Many thanks. Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted May 2, 2012 Share Posted May 2, 2012 On my roadsters roof, it was looking a bit tired and dirty, and I used this product: http://www.halfords.com/webapp/wcs/stor ... yId_255237 It has a cleaner in it which you brush on to clean it all up, then some sort of silicone spray stuff which bonds to the roof to make it water proof. It was easy to go on, and I was amazed with the end results. It looked like a brand new hood. Nice, clean & dark. I reckon id probably only need to do this twice a year max to keep it looking new. Im not sure if it will solve your problem with the tide marks, but it may well do. Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted May 2, 2012 Author Share Posted May 2, 2012 is this product any good as I think it was the AG product that caused the problem in the first place http://www.amazon.co.uk/RaggTopp-Fabric ... 715&sr=8-2 Quote Link to comment Share on other sites More sharing options...
NeilMH Posted May 2, 2012 Share Posted May 2, 2012 +1 to Autoglym kit. If I wanted to renovate/recolour I would use black Renovo Soft Top Reviver (the one for Canvas/Mohair etc). Quote Link to comment Share on other sites More sharing options...
KC350Z Posted May 2, 2012 Share Posted May 2, 2012 +1 autoglym but more than likely was cleaning stuff you used but autoglym can do the same if not used evenly across the hole roof as looking at pics you can see where you srayed the stuff on roof {so i would say dont spay so close so i spreads better} try doing roof again but dont spray so close and make sure you have even coverage Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted May 2, 2012 Author Share Posted May 2, 2012 thanks for the advice. will try cleaning it again and will spray from a further distance. is there any harm if I don't get round to doing this until the weekend do you think? Quote Link to comment Share on other sites More sharing options...
KC350Z Posted May 2, 2012 Share Posted May 2, 2012 no will be fine i had the same with mine first time i done it Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted May 3, 2012 Author Share Posted May 3, 2012 how did you prevent the spray from getting on to the paintwork or glass? Quote Link to comment Share on other sites More sharing options...
rabbitstew Posted May 3, 2012 Share Posted May 3, 2012 how did you prevent the spray from getting on to the paintwork or glass? The guide I read said open unlatch the roof, then put a sheet or something under the roof covering the body work. Personally I didnt bother. I just sprayed it straight on and used a newspaper held in the other hand against the bodywork top prevent any getting on the bodywork. If any went on the glass I wiped off immediately and then later polished up all the glass anyway. I also didnt worry about how thick i sprayed the stuff on. It all looked a bit strange when it first goes on the roof, but dried perfectly and left no streaks or spray marks. Quote Link to comment Share on other sites More sharing options...
KC350Z Posted May 3, 2012 Share Posted May 3, 2012 how did you prevent the spray from getting on to the paintwork or glass? The guide I read said open unlatch the roof, then put a sheet or something under the roof covering the body work. Personally I didnt bother. I just sprayed it straight on and used a newspaper held in the other hand against the bodywork top prevent any getting on the bodywork. If any went on the glass I wiped off immediately and then later polished up all the glass anyway. I also didnt worry about how thick i sprayed the stuff on. It all looked a bit strange when it first goes on the roof, but dried perfectly and left no streaks or spray marks. +1 i just had spare cloth and wiped off over spray just make sure you get even coverage and will be ok Quote Link to comment Share on other sites More sharing options...
KC350Z Posted May 13, 2012 Share Posted May 13, 2012 Hi All Wondered if someone would be able to advise how to go about removing the following marks from my canvas roof. I believe that this has been caused by the AG roof cleaner product and am hoping that its pretty easy to remove. I have washed the roof with Megs and the marks have returned this morning, they are not that bad but are annoying me more. Many thanks. Did you manage to sort this in the end mate Quote Link to comment Share on other sites More sharing options...
