Shinjuku Posted April 30, 2012 Share Posted April 30, 2012 Is there a diagram or picture anywhere showing the safe points on the under side of the car for placing a trolley jack and axle stands. Thanks Shinjuku (search is not the best on tapatalk) Quote Link to comment Share on other sites More sharing options...
JT350GT4 Posted April 30, 2012 Share Posted April 30, 2012 Check in the manual? . Just don't jack it up using the underbody footwells, I think they're pretty soft Quote Link to comment Share on other sites More sharing options...
simon da silva Posted April 30, 2012 Share Posted April 30, 2012 http://my350z.com/forum/picture.php?pictureid=14977 Quote Link to comment Share on other sites More sharing options...
Shinjuku Posted April 30, 2012 Author Share Posted April 30, 2012 Surely people do something different in practice than what is on that diagram. If you put a trolley jack on the sill there you will chew the sill edge up on the jack head. Plus there is nowhere to put a stand as the skirt runs up to the edge of the sill meaning you risk cracking it. What do people do in practice. Quote Link to comment Share on other sites More sharing options...
Lexx Posted April 30, 2012 Share Posted April 30, 2012 Go out onto your drive with a torch. Lay down behind your front wheel. Look at the sill ridge under the car. You will see 2 x "dimples" in the sill metal. Between these 2 points is the jacking point. And these are exactly where garage lifts go. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted April 30, 2012 Share Posted April 30, 2012 viewtopic.php?f=9&t=59010&hilit=jacking And viewtopic.php?f=13&t=58997&hilit=jacking Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 30, 2012 Share Posted April 30, 2012 Surely people do something different in practice than what is on that diagram. If you put a trolley jack on the sill there you will damage it. Plus there is nowhere to put a stand as the skirt runs up to the edge of the sill meaning you risk cracking it. What do people do in practice. Where do garages with two post lifts lift it for example You can use the standard bits for using the stands if you put the stands parallel to your car. Quote Link to comment Share on other sites More sharing options...
Shinjuku Posted May 1, 2012 Author Share Posted May 1, 2012 Ok thanks all I will take a look. Quote Link to comment Share on other sites More sharing options...
cmck13 Posted May 1, 2012 Share Posted May 1, 2012 You'll find that if you are using the sill jacking point its not uncommon for a small mod to be made by yourself. Take a small piece of wood 1/2" inch thick, cut to fit snug on top of your jack or stand and saw a slot down it about 1/8" deep to fit on the sill point. Otherwise you are still able to use the main garage jacking points as in the schematic that you have probably seen earlier. Quote Link to comment Share on other sites More sharing options...
Mickeywheelspin Posted May 1, 2012 Share Posted May 1, 2012 If I'm in a rush I use the sill jacking points with the jack in the boot, otherwise I use the trolley jack and use the central points under the car and lift the whole front and back. I've got an off cut of wood that I keep meaning to cut a groove in, but I'm just too lazy. Another often used trick is to cut a groove in a hockey puck. Quote Link to comment Share on other sites More sharing options...
