Greddy-Matt Posted April 29, 2012 Share Posted April 29, 2012 Hi all! Thought I'd make a start on blinging my engine bay, I have a massive list to do and parts to get but started on polishing all of the cast parts of the engine and block that are visible. I've been using a dremel with a cotton wheel and autosol, it's bringing it up nicely but it's taking an age (it took an hour and a half to do a couple of inches! ) does anyone know if there's a more abrasive metal polish available, or a better method of polishing (I can't use wet and dry because it's impossible to get everywhere with it)? Any advice welcome!! Quote Link to comment Share on other sites More sharing options...
JT350GT4 Posted April 29, 2012 Share Posted April 29, 2012 Buy a pre-done one off Wasso ? Quote Link to comment Share on other sites More sharing options...
Ricey Posted April 29, 2012 Share Posted April 29, 2012 Do you mean the plenum? Quote Link to comment Share on other sites More sharing options...
Greddy-Matt Posted April 29, 2012 Author Share Posted April 29, 2012 Hi No not the plenum, I'm looking to paint that with either black or red wrinkle paint I'm polishing all of the metalwork at the front of the engine i.e. where all the belts are, where all the sensors go into etc, I'll try and get some pics up of what i'm doing Quote Link to comment Share on other sites More sharing options...
Watshot Posted April 29, 2012 Share Posted April 29, 2012 all of the cast parts of the engine and block that are visible. I've been using a dremel with a cotton wheel and autosol, That would be more for final finishing. Initially you need something far more aggressive like a drill with wire brush wheel etc. Obviously with the parts you want to do this is only feasible if they are removed from the engine, which is why most folk who want this type of thing on a DE engine generally do the plenum as it's highly visible, and easily removed. On an HR it isn't a problem. Not familiar with the DE, but on the HR only one timing chain cover is easily removed without any stripping down. Quote Link to comment Share on other sites More sharing options...
SwanageDave Posted April 29, 2012 Share Posted April 29, 2012 My Advice would be....Shut the Bonnet go to the pub get pi**ed whoever see's the bloody engine bay? Mechanics and service crew...They may think youre on the pull Quote Link to comment Share on other sites More sharing options...
Wasso Posted April 29, 2012 Share Posted April 29, 2012 I've already made investigations to obtain a replacement timing cover get it polished and fit. The timing cover is problematic, mainly due to the intricate moulding. It can be done but will take a VERY long time. The finish won't be that great either. I will have mine proffesionaly polished due to the hassle. If you're looking for a plenum or oem strut polished or anything else I can do it for you. Polished Plenum viewtopic.php?f=38&t=59850 Polished Strut viewtopic.php?f=38&t=60698 Example of my ARC box I decided to polish recently, turned out a treat. Before After Quote Link to comment Share on other sites More sharing options...
JT350GT4 Posted April 29, 2012 Share Posted April 29, 2012 Wow Wasso mirror shiny Quote Link to comment Share on other sites More sharing options...
Wasso Posted April 29, 2012 Share Posted April 29, 2012 Wow Wasso mirror shiny Funny thing is it was unpolished for two years and never thought to clean her up. Makes a massive difference. I polish anything these days, even our cat shines now Quote Link to comment Share on other sites More sharing options...
TEMPERZ Posted April 29, 2012 Share Posted April 29, 2012 If you really want to do it use a wire brush to get the oxidisation off as above. Then use a cutting compound like G3 or 3M Fast cut to get a good surface. Then your better off using a polish called Peek, its much cleaner than autosol and cheaper, you can get a 1kilo tin for around £15. Its designed for aluminium in particular and its the nuts Your a brave man though, it will take you a long old time Quote Link to comment Share on other sites More sharing options...
Greddy-Matt Posted April 29, 2012 Author Share Posted April 29, 2012 Thanks for the replies! I am intending to do everything I can get my mitts to, these are the sort of bits that I'm looking to start with tho (you can just about make out a tiny bit I did yesterday peeking out from under the engine cover): I'll grab a wire brush and take a trip to the local motor factors for some cutting compound tomorrow morning as I have the day off to tinker, PEEK sounds interesting I'll try anything once tho so will give it a shot Time isn't an issue, happy to do it bit by bit as I bought the car to keep it untill it dies, tho I suspect by the time I'm done, I'll have to start all over again Wazzo - thats impressively shiney! Might have to re-think painting the plenum now, do you think a throttle body is do-able? Quote Link to comment Share on other sites More sharing options...
Wasso Posted April 29, 2012 Share Posted April 29, 2012 I've started doing my throttle body, and the easy parts have come up a treat and only took 5 mins as I've purchased everything you can dream of for polishing. Drill, Dremel, polishing machine, mops, mini mops, micro mops, abrasive bits for the drill and Dremel and a wealth of varying wet and dry sand paper. Oh and 3 compounds for the polishing mops cut, medium and shine. The plenum will take you a long time. My first one took nearly 40 hours, but now have it down to about 16hrs. Be careful with te throttle body as it obviously contains sensitive components. I will potentially be selling polished throttle bodies in the future. Wet and dry is fine, but the polishing wheel does a great job. Quote Link to comment Share on other sites More sharing options...
Voodoo Vix Posted April 29, 2012 Share Posted April 29, 2012 Both my plenum and throttle body are polished, the actual block which you're trying to polish I'm hopefully getting painted, so much easier than keeping it shiny lol Quote Link to comment Share on other sites More sharing options...
