Revsport Posted February 19, 2007 Share Posted February 19, 2007 We need him on here as a sponsor. http://www.my350z.com/forum/showthread.php?t=250332 Its so JDM Lew Quote Link to comment Share on other sites More sharing options...
Digsy Posted February 19, 2007 Share Posted February 19, 2007 LMAO Don't reckon the lad'll be posting a response soon. They're ruthless over there but he deserves it. What's with all the Honda bashing? Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted February 19, 2007 Share Posted February 19, 2007 You are not logged in or you do not have permission to access this page. This could be due to one of several reasons: 1. You are not logged in. Fill in the form at the bottom of this page and try again. 2. You may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system? 3. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. Quote Link to comment Share on other sites More sharing options...
Digsy Posted February 19, 2007 Share Posted February 19, 2007 You are not logged in or you do not have permission to access this page. This could be due to one of several reasons: 1. You are not logged in. Fill in the form at the bottom of this page and try again. 2. You may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system? 3. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. Yup, you need to be a member on MY350Z. Quote Link to comment Share on other sites More sharing options...
Revsport Posted February 19, 2007 Author Share Posted February 19, 2007 Here is how it reads. ATCmotorsport's 350Z Single Turbo Kit $950 (Shipped) -------------------------------------------------------------------------------- JDM SPORT T3/T4: Stage-3 Turbo T3/T4 Compressor 3" Inlet Diameter ad 2"Outlet Wet Float Bearing 1/8 NPT Oil Inlet .50 A/R Compressor .63 A/R Turbine .57 Compressor Wheel Trim. 35PSI of Peak Boost OIL FEED LINE KIT: High quality stainless steel Oil feed return line for T3 T4 Turbo kit. 36" long stainless steel braided line with 3/8" diameter. 1/8" Adapter NPT male fitting that goes to the block and one- 4AN male fitting built on flange.(made from Grade 7075 Alum). Comes with gasket and screw/washers. RS BLOW OFF VALVE: Brand New High Quality Product. JDM Type-RS Turbo Blow off Valve Style.(Dual Stage pull-Type Relief Valve). Protect your turbo by releasing pressure surges when changing/shifting gears or backing off throttle quickly Perfect for almost ANY turbo'd application WATEGATE: Brand New High Performance 38mm External Turbosmart Wastegate. To manage the upper-deck air pressure the turbocharger's exhaust gas flow is regulated with a wastegate that bypasses excess Exhaust gas entering the turbocharger's turbine. This regulates the rotational speed of the turbine and the output of the compressor. This regulates the rotational speed of the turbine and the output of the compressor. The wastegate is opened and closed by the compressed air from turbo (the upper-deck pressure) and can be raised by using a solenoid to regulate the pressure fed to the wastegate membrane. This solenoid can be controlled by Automatic Performance Control, the engine's electronic control unit or an after market boost control computer. Another method of raising the boost pressure is through the use of check and bleed valves to keep the pressure at the membrane lower than the pressure within the system. FUEL PRESSURE REGULATOR: 100% Brand New High Quality Product. JDM adjustable fuel pressure regulator Light weight designed. Made of CNC billet aluminum. Increase fuel delivery by raising pressure.(increase HP 5-10). It can provide precise consistent boost as much as twice of the Factory fuel flow. SIDE MOUNT COOLER: Brand New Front Mount Intercooler. All TIG Welded 6061 Aluminum All hand Welded. 100% Brazed Core (No Epoxy). High Efficiency Bar & Plate Construct. High Flow Tube & Fin Construction. Core Length: 21" x 7" x 2.5". . Overall Leghth: 28" x 7" x2.5". Inlet & Outlet is 2.5" PIPING KIT: JDM Aluminum 2.5" Intercooler Piping w/ Silicone Hose. Its Made out of High quality of 6061 Aluminum Meterial Black Coated Finshed. Made out of High Quality Material. Extra thick Piping 1/16 Inches. Made by JDM Sport BLue Silicone Hoses The Kit Offers up to 40%-60% increase flow http://img369.imageshack.us/img369/8205 ... bogqa5.jpg Testings shows increases of +225HP Quote Link to comment Share on other sites More sharing options...
Revsport Posted February 19, 2007 Author Share Posted February 19, 2007 Its cheap nasty stuff that the guy buys off ebay then re sells on on my350z. He states that it might need a lot of work to fit. lol. The Honda thing is because in the US they dont have saxos and corsas so civics are there saxos where loads of @*!# is put on them Quote Link to comment Share on other sites More sharing options...
Removed Posted February 19, 2007 Share Posted February 19, 2007 looks like they got rid of all those shite adverts for resistors etc from these guys, after most people started taking the **** tuning shops included Quote Link to comment Share on other sites More sharing options...
