Dicky Posted April 26, 2012 Share Posted April 26, 2012 Anyone noticed their air con intermittantly switching on by itself. Mine seems to have started to do it . Ive tried tapping the switch and surrounding area but cant get it to come. Any ideas welcome Its a pain cos when you switch off again the screen fogs up. Quote Link to comment Share on other sites More sharing options...
SteveW Posted April 26, 2012 Share Posted April 26, 2012 When you turn the fans to windscreen air con comes on automatically. Quote Link to comment Share on other sites More sharing options...
Ebized Posted April 26, 2012 Share Posted April 26, 2012 Have you got it set on auto - which from what you describe would be normal. With the weather we have had of late it is quite normal to have the air-con on all the time to stop the misting, especially if all your windows are shut. I'm presuming you have the setting for incoming air as opposed to recirculating in the car which would certainly cause the misting on wet days without the air-con on. Quote Link to comment Share on other sites More sharing options...
Dicky Posted April 26, 2012 Author Share Posted April 26, 2012 The controls are set to Auto and for incoming air (not recirc). Odd times when driving I look down and the air con light is on but I didnt select it. Its happenes quite often but Ive never been able to connect its switching on to any event with the car (like hitting a bump in the road/other)?? As I said Ive tried banging around the controls in case theres a loose connection but it doesnt come on. Quote Link to comment Share on other sites More sharing options...
Ebized Posted April 26, 2012 Share Posted April 26, 2012 Its generally reckoned its best to leave the air-con on all the time in a ZED, although I'm one that whenever possible wil have the window open, if only a smidgen, and find having it on full time is not necessary. Try leaving it on for a week or two and see if you still have problems. Quote Link to comment Share on other sites More sharing options...
Big Rob Posted April 26, 2012 Share Posted April 26, 2012 Anyone noticed their air con intermittantly switching on by itself. Mine seems to have started to do it . Ive tried tapping the switch and surrounding area but cant get it to come. Any ideas welcome Its a pain cos when you switch off again the screen fogs up. Mine does this too but I haven't worked out why yet, it might be because the cabin temp has risen above the temp set on the dial. I don't think it does it if you turn the fan to the off position. Quote Link to comment Share on other sites More sharing options...
Levi Posted April 26, 2012 Share Posted April 26, 2012 When you turn the fans to windscreen air con comes on automatically. +1 It's a common feature on most cars that the air-conditioning is automatically switched on when the directional controls are set to windscreen in order to prevent fogging. Quote Link to comment Share on other sites More sharing options...
Dicky Posted April 29, 2012 Author Share Posted April 29, 2012 Bloody TECHNOLOGY always interfering when youndont want it When you switch the aircon off again everything mists up. Quote Link to comment Share on other sites More sharing options...
