Jobo Posted February 18, 2007 Share Posted February 18, 2007 Hi Guys, Finally got my V+ Plenum yesterday from Kinetix and got it fitted this morning. It was pretty straight forward to fit and pretty self explanatory, although i followed the instructions exactly, just to be sure! Only real problem i had was that the throttle body, when fitted to the V+, sits at a slightly different angle than it does on the standard plenum, and i had to make a small aluminium bracket to fit from the engine mounting point to the intake tube on my typhoon kit. I presume if using the standard plastic intake tube you wouldnt have this problem and there would be enough flex in the corrogated section?? Anyway, the Typhoon has been fitted for a couple of weeks now, and unless you rev the car over 4k revs, you dont really notice the kit is there! Now, however, it has a very 'throaty' sound, even at low revs ie, in town driving pulling away from lights etc. Overall very pleased with piece of kit and service, as for the gains which Kinetix claim, well im not sure, but its always far too easy just to think its giving the car more power just with the noise it produces. Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 18, 2007 Share Posted February 18, 2007 you just want an exhaust now Quote Link to comment Share on other sites More sharing options...
Jobo Posted February 18, 2007 Author Share Posted February 18, 2007 Hmm not so sure, dont want to be too loud thats my problem! Quote Link to comment Share on other sites More sharing options...
sinbad Posted February 18, 2007 Share Posted February 18, 2007 you can't have all the sound coming from the engine, you need a balance. Just get yourself a cat-back and you'll be sorted. he he! Quote Link to comment Share on other sites More sharing options...
Mathys Posted February 20, 2007 Share Posted February 20, 2007 Was there any cooling liquid coming out of the 2 hoses underneath the throttle body? I want to remove my stock plenum as well to get it polished/chromed. However, will it be needed to refill the cooling system + removing the air?? Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 21, 2007 Share Posted February 21, 2007 Was there any cooling liquid coming out of the 2 hoses underneath the throttle body? I want to remove my stock plenum as well to get it polished/chromed. However, will it be needed to refill the cooling system + removing the air?? you will get a drop or two of coolant loss ,but nothing to worry about, just reconnect when you replace plenum Quote Link to comment Share on other sites More sharing options...
Mathys Posted February 22, 2007 Share Posted February 22, 2007 you will get a drop or two of coolant loss ,but nothing to worry about, just reconnect when you replace plenum Tnx! Did you put a special clamp on the hoses or is there a clamp on them anyway to secure them with the plenum? Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 22, 2007 Share Posted February 22, 2007 you will get a drop or two of coolant loss ,but nothing to worry about, just reconnect when you replace plenum Tnx! Did you put a special clamp on the hoses or is there a clamp on them anyway to secure them with the plenum? Think I used original clamps Quote Link to comment Share on other sites More sharing options...
stuey Posted February 22, 2007 Share Posted February 22, 2007 you will get a drop or two of coolant loss ,but nothing to worry about, just reconnect when you replace plenum Tnx! Did you put a special clamp on the hoses or is there a clamp on them anyway to secure them with the plenum? Think I used original clamps lomotos saving his nipple clamps for anothe occasion.........!!!!! Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 22, 2007 Share Posted February 22, 2007 you will get a drop or two of coolant loss ,but nothing to worry about, just reconnect when you replace plenum Tnx! Did you put a special clamp on the hoses or is there a clamp on them anyway to secure them with the plenum? Think I used original clamps lomotos saving his nipple clamps for anothe occasion.........!!!!! your mind works at a strange tangent stuey Quote Link to comment Share on other sites More sharing options...
stuey Posted February 22, 2007 Share Posted February 22, 2007 you will get a drop or two of coolant loss ,but nothing to worry about, just reconnect when you replace plenum Tnx! Did you put a special clamp on the hoses or is there a clamp on them anyway to secure them with the plenum? Think I used original clamps lomotos saving his nipple clamps for anothe occasion.........!!!!! your mind works at a strange tangent stuey it was the word clamps that sent me down that path............!! Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 22, 2007 Share Posted February 22, 2007 you will get a drop or two of coolant loss ,but nothing to worry about, just reconnect when you replace plenum Tnx! Did you put a special clamp on the hoses or is there a clamp on them anyway to secure them with the plenum? Think I used original clamps lomotos saving his nipple clamps for anothe occasion.........!!!!! your mind works at a strange tangent stuey it was the word clamps that sent me down that path............!! that will be a long twisty path I think Quote Link to comment Share on other sites More sharing options...
stevie_350z Posted February 22, 2007 Share Posted February 22, 2007 Path with no return either! Kinky! No wonder Bluelady did a runner... Quote Link to comment Share on other sites More sharing options...
stuey Posted February 22, 2007 Share Posted February 22, 2007 Path with no return either! Kinky! No wonder Bluelady did a runner... nothin to do wiv me................. Quote Link to comment Share on other sites More sharing options...
Jobo Posted February 24, 2007 Author Share Posted February 24, 2007 Yeh like lomoto said, just a few drops of coolent loss and just use the original clamps It is quite a bit louder now, i thought it was the typhoon so i took it off today and fitted the stock airbox etc again, but the extra noise is definitely produced by the plenum! Lomoto, is there any kind of a whine coming from your car now? Ive noticed that there is a definitive whine when under slight accelarion, ie town driving, comes and goes under light acceleration/coasting? I checked all the bolts today just to make sure it was a 100% seal and they are fine. Am i just being paranoid??! Quote Link to comment Share on other sites More sharing options...
lomoto Posted February 25, 2007 Share Posted February 25, 2007 Yeh like lomoto said, just a few drops of coolent loss and just use the original clamps It is quite a bit louder now, i thought it was the typhoon so i took it off today and fitted the stock airbox etc again, but the extra noise is definitely produced by the plenum! Lomoto, is there any kind of a whine coming from your car now? Ive noticed that there is a definitive whine when under slight accelarion, ie town driving, comes and goes under light acceleration/coasting? I checked all the bolts today just to make sure it was a 100% seal and they are fine. Am i just being paranoid??! Your paranoid I think it will just be the extra induction roar from the plenum as it is not as thick walled as the original alloy one..? Quote Link to comment Share on other sites More sharing options...
Rob2005 Posted March 8, 2007 Share Posted March 8, 2007 Ive noticed the same sort of thing. I also have a rattle from the engine bay at high revs that echoes through the car.. Although i did have to leave the Typhoon bracket off and i think its this which is vibrating... Not sure.... I havent noticed a massive improvement either if im honest, the BHP claims of K&N and Kinetix should have given approx 20-25 bhp.. I dont think ive got half that.. Anyone else noticed a big/dissapointing difference?? Quote Link to comment Share on other sites More sharing options...
sl114 Posted March 8, 2007 Share Posted March 8, 2007 I havent noticed a massive improvement either if im honest, the BHP claims of K&N and Kinetix should have given approx 20-25 bhp.. Only if you have a piggyback ECU i think Quote Link to comment Share on other sites More sharing options...
Removed Posted March 8, 2007 Share Posted March 8, 2007 the Kinetix plenum IS noisy. both extra induction noise but I also remember a "plasticky" type noise and vibration coming from it. I didn't like that. Also, make sure the strut bar doesn't vibrate against the bonnet, as I had to adjust it quite a bit to make it clear the Plenum. WRT gains, I did certantly feel the difference, and when I took it off, again I felt the difference (ie less hp) and again when I put my spacer on, I certaintly feel it. Quote Link to comment Share on other sites More sharing options...
Rob2005 Posted March 10, 2007 Share Posted March 10, 2007 MY Strut bar is rubbing the plenum slightly and is also hitting the strengthener on the bonnet. Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted March 10, 2007 Share Posted March 10, 2007 MY Strut bar is rubbing the plenum slightly and is also hitting the strengthener on the bonnet. You should only need to shorten the strut bar (tighten it) slightly and this will raise it away from the engine cover and transversely away from the bonnet too, since it raises in the middle - like the handles on a supermarket basket, when you have a very heavy weight in Not the V+ but same principle Quote Link to comment Share on other sites More sharing options...
Rob2005 Posted March 11, 2007 Share Posted March 11, 2007 Great, ill give it a go Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted March 11, 2007 Share Posted March 11, 2007 Page from manual .... which basically says undo the outside bolts (which are for locking in place), turn centre bolt to adjust (shorten/lengthen) and then re-tighten outside locking bolts. Don't get too hung up on the alignment it talks about, just adjust until you have about 6mm clearance from the engine cover Quote Link to comment Share on other sites More sharing options...
