Dblock Posted April 25, 2012 Share Posted April 25, 2012 My JDM's been run on super always. So will most other imports. If Sarnie keeps quiet the value of them will rocket. Quote Link to comment Share on other sites More sharing options...
KC350Z Posted April 25, 2012 Share Posted April 25, 2012 My name is SpursMadDave and I have on occasion used 95 Ron in my Zed Quote Link to comment Share on other sites More sharing options...
docwra Posted April 25, 2012 Share Posted April 25, 2012 My JDM's been run on super always. So will most other imports. If Sarnie keeps quiet the value of them will rocket. I think its probably a greater issue for the JDM's as they are originally mapped to use 100 RON. 95 RON might not kill a perfectly working engine, but any issue with the MAF, inlet air leaks or similar are going to be a lot more likely to cause damage than if you were on Super. Its a much bigger issue on FI engines, Ive driven a standard Evo that was detting its tits off on 95 RON (the guy in the garage didnt even realise) but even with NA I wouldnt risk it myself. Quote Link to comment Share on other sites More sharing options...
Dicky Posted April 25, 2012 Share Posted April 25, 2012 Tesco Momentum is 99 +1 Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted April 25, 2012 Share Posted April 25, 2012 Tesco Momentum is 99 +1 So is it 99 or 100 Quote Link to comment Share on other sites More sharing options...
Chris`I Posted April 25, 2012 Share Posted April 25, 2012 My JDM's been run on super always. So will most other imports. If Sarnie keeps quiet the value of them will rocket. I think its probably a greater issue for the JDM's as they are originally mapped to use 100 RON. 95 RON might not kill a perfectly working engine, but any issue with the MAF, inlet air leaks or similar are going to be a lot more likely to cause damage than if you were on Super. Its a much bigger issue on FI engines, Ive driven a standard Evo that was detting its tits off on 95 RON (the guy in the garage didnt even realise) but even with NA I wouldnt risk it myself. Theoretically you could also get into more trouble when running with breathing mods (intakes/exhausts/etc) when you could be running lean. Running lean could cause it to run hotter which cases more det. Coupled with 95RON thats not a good combo. All ok if you are mapped for it though, its just the stock map doesnt appear to be flexible enough to wind timing back enough. Agree though, most driving wont cause any problem at all with 95RON as its below 5kRPM. The main problem is a lot of members on here dont know how to change their driving style with 95RON Quote Link to comment Share on other sites More sharing options...
docwra Posted April 26, 2012 Share Posted April 26, 2012 Yep, had a friend with a totally standard PPP Impreza, had no issues with it at all. Changed the exhaust (didnt even decat) and within 3 weeks he had a lunched engine. Quote Link to comment Share on other sites More sharing options...
