FUG Posted May 31, 2012 Author Share Posted May 31, 2012 hmmm a lot has been sold and a lot of positive feedback, for a few quid its probably worth a go! not overly fussed about how realistic it looks, just anything to cover up some of the cheap matt black plastic parts will do nicely! Quote Link to comment Share on other sites More sharing options...
FUG Posted June 7, 2012 Author Share Posted June 7, 2012 Just finished wrapping the number plate surround looks ok for a first attempt and considering that only a thin bit of the surround shows it could be worse! Will try get some pics up. Will see how the cheap stuff holds up in the british weather. Have a few offcuts left, any good ideas on small parts to wrap, perhaps stuff inside the cabin?? Quote Link to comment Share on other sites More sharing options...
car350z Posted June 8, 2012 Share Posted June 8, 2012 I'd just buy some film from ebay and play around with it on small, simple shapes. Gradually you can move to more complex shapes. It's not too difficult once you get a feel for how the film stretches when hot. You'll also need a bunch of really sharp (razor) blades and a hairdryer/heatgun. Once you're comfortable you can move on to important parts (the Zed). I've been playing around with 3M Di-Noc a bit recently and each time I wrap something, I learn something new, just try it mate Quote Link to comment Share on other sites More sharing options...
14N Posted June 18, 2012 Share Posted June 18, 2012 FUG, any pics of your wrapped number plate mounting bracket? I've thought about doing mine as I've a few off cuts of vinyl that might be enough to do the job. Just be interested to see how it looks. Cheers Quote Link to comment Share on other sites More sharing options...
FUG Posted July 18, 2012 Author Share Posted July 18, 2012 Not the best pic (or angle) in the world, taken from a mobile - hopefully gives you some idea. Quite pleased with the turn out, looks subtle enough and disguises the cheap black plastic OEM surround, not bad for a first time wrapper!! Quote Link to comment Share on other sites More sharing options...
FUG Posted January 17, 2013 Author Share Posted January 17, 2013 (edited) Now what to wrap next Hmm some interior bits I think. A lot of people do the rear strut bar insert I've noticed, is this easy to remove?? Also going back to earlier - rear number plate is stuck on I presume?? Is it easy to remove without damaging anything or paintwork?? Thanks Edited January 17, 2013 by FUG Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted January 17, 2013 Share Posted January 17, 2013 Easy to remove, if you want to pop round I can help you take it off. I'm in kesgrave. If not its just a case of separating all the black plastic around it. All plastic bung fittings. Sharp tug and they're off. Quote Link to comment Share on other sites More sharing options...
FUG Posted January 23, 2013 Author Share Posted January 23, 2013 Thanks for offer rtbiscuit I'm Undecided at min what to wrap I have a bit of cf wrap left over so may as well use it, is it easy enough to remove the wrap if not happy with it or want to change it later down the line? ? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted January 23, 2013 Share Posted January 23, 2013 Yes but you need to use heat to reactivate the adhesive Quote Link to comment Share on other sites More sharing options...
DarmoZ Posted January 11, 2016 Share Posted January 11, 2016 Iv'e used some 3M Scotchprint recently to do my Keys, B-Pillars, Ariel and Fuel cap, all turned out really good, iv'e never wrapped before but it wasn't too difficult, hopefully they will hold up. I want to do the door handles next which will be challenging but possible, then finally wing mirrors and rear spoiler. £17 for a roll of scothprint and £6 for a heat gun and squigee of ebay. Quote Link to comment Share on other sites More sharing options...
