Flat centre caps for standard 18s?
Shinjuku
I would like to investigate what my options are for using a decal on the centre caps with the standard 18's. I assume the standard centre caps will be hopeless due to the embossed emblem.
Does anyone know what centre caps I might use. Ideally I would go for a set of flat caps from another car which I could pick up secondhand for minimal money. Would this be possible.
What size centre caps would I need and does anyone know of any flat ones which might fit?
Cheers
Shinjuku
on the centre caps there are the nissan burgers. if you remove them from the wheel, you will see two little plastic "melted" rivets, drill these out and then the burgers just push out from the back.
gives you a smooth surface to stick something too. the transformer discs i got were convex in shape and fitted quite nicely. im sure that someone here does JEL coat overlays for the centre caps.
